So yesterday I put FOBO TP monitors on my FLHTK. Man very easy to install and way easy to set-up. and working great. Checked them against my digital gauge and they were spot on. If you thought about trying these I give them two thumbs up so far. Way cheaper than trading my bike in for a CVO. I will keep anyone informed on them. If interested.
Shaun
Originally Posted by 02BlueDeuce
I've had them for about 6 months on my 14 SGS. Work great and as you said, way cheaper than trading for a new bike.
By far the best mod I have done to my bike, I just installed the FoBo two-way valve stems when I changed tires. Do not have to remove the saddlebag anymore to increase or decrease pressure.
FOBO fan here too. Doubt I'll ever have another bike without either a built in system or an add on like this.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the LINKSbelow...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Mine are one lb low compared to a calibrated gauge, not enough to worry about. I'm getting another set for my trailer, my biggest fear when trailering is that I get a flat at 80mph, these give me a little piece of mind. I have a set of 4 that read to 50lbs if anyone is interested. My trailer tires need 65 I believe.
