PV Tune question
So should I contact Fuel moto for another tune, or keep auto tuning? Opinions?
By utilizing the PV for LOG record, mytune will provide you best numbers for your bike, even for spark advance. In my case I was able to get a very good map with only four runs (map is fine when the the average tables value adjustments are within 0,5%-1%) with both my bikes, a 16 FLTRU and a 09 FXDC.
More information here: https://tunemyharley.com
I always do a couple 20-30min auto tune sessions, just to dial in the tunes to my specific Bike's VE (volumetric efficiency)...
I happen to also have the old Auto Tune Pro Module that uses the wide band O2 sensors for the dialing in of the VE tables....
I have never needed to do more than one or two Auto tune sessions, even with the wide band auto tune pro.... to get the average change in the VE tables to 4% or less...
Once dialed in by auto tune, the tunes will match up to your bike pretty closely...
If there is rideability issue somewhere in the tune parameters, just send a data log to FuelMoto and they will dial it in.....
Example: They dyno tuned my 124" crate engine in their shop on a cool October day in Wisconsin....
Eight months later I was riding in 105° heat, here in SoCal, and thought I heard some pinging....
I sent them a datalog, they spotted a couple knock events, adjusted the tune, and sent it back... All good now...!!
If no leaks found you can send your tune to fuel moto, they will make adjustments and send the tune back to you, to flash to your ecm.
I'd post this in this in the Ignition/tuner section. Alot of knowledgeable people there.
edit; The bike actually seems to run pretty darn good, but I am concerned about the lean plugs.
I'd run a few more auto tune runs and see if that makes a difference. Look at your VE tables and see if the numbers are changing less after each uto Tune run.
If not get ahold of fuel moto, they will help ya out.
If you were talking to me, I have a 103" engine. I also have the aluminum backing plate by SE. i am in the process of modding my SE slip ons, and will try several runs at autotune before I take other steps.
To watch live fuel corrections (short term fuel trims) with your Power Vision you can view the channels Front & Rear Closed Loop Integrator (CLI), these channel represent a +/- multiplier of the live fuel corrections as a %. For stored (Adaptive) corrections (long term fuel trims) you can view Front & Rear Adaptive Fuel Factor (AFF). See the following from the FM University site:
- the Closed Loop Integrator (CLI-short term fuel trim) will be active during normal riding conditions. This value should constantly swing up and down constantly, where the value of 100 is the pivot point. For example if a CLI value of 103 is reported, that means the ECM had to add 3% to the respective front or rear cylinder VE table in order to achieve the target AFR or Lambda. Conversely, the value of 97 would indicate the ECM had to subtract 3% to the respective front or rear cylinder VE table in order to achieve the target AFR or Lambda. To view these channels, assign them to a gauge. Youre looking for Front Closed Loop Integrator and Rear Closed Loop Integrator.
- If you have Adaptive Fuel enabled in your calibration, then you should also notice Adaptive Fuel Factor (AFF) change over time. These learned values will move, or change much slower than the CLI. When the proper conditions have been met the ECM will generate long term/long term fuel trims (AFF). If you see a AFF value of 105 reported, that means the ECM has applied 5% to the respective front or rear cylinder VE table in order to achieve the target AFR or Lambda. Conversely, the value of 95 would indicate the ECM had to subtract 5% to the respective front or rear cylinder VE table in order to achieve the target AFR or Lambda. To view these channels, assign them to a gauge. Youre looking for Front Adaptive Fuel Factor and Rear Adaptive Fuel Factor
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
I started making these changes after starting this thread, so I will have to pick up where I left off or start new.
