Adding TPMS to Rushmore Bikes
I can report that I have made some progress with this project. While my Harley dealer does not want anything to do with it, I have found an Indy shop that is willing to try.
Starting off on a positive note, the Harley TPMS sensors PN#42300124 fit my stock rims with just the beveled seal from FOBO. It is unfortunate that I had to but two complete FOBO t-valves, but oh well
I have acquired a BCM with part number 41000341a from a 2017 Harley model and provided it to the Indy shop. They have installed it on the bike and connected it to their TechnoResearch diagnostic tool attempting to marrying the BCM to my bike. So far they have not been successful. Is this something that needs to be done by the Harley dealer using their proprietary diagnostic tool?
The only thing I dont have yet are new FOBs.
Any comments or suggestions as to where to go from here?
Thanks in advance.
Second, the BCM you "acquired" is it new or used?
Reason I ask is TechnoResearch's software has very specific module replacement instructions for the BCM, and Step 7 of that process mentions "If you do not receive zero’s in all the boxes, like shown below then your BCM is NOT new." But it doesn't go on to say what to do if you find yourself in that situation, or if you MUST have a new/unused BCM.
Here's a link to that page, if it works.
http://technoresearch.info/Jobs/Replacing-a-BCM.html
Lastly, I have TechnoResearch's Centurion Super ProPlus, and I am very new to it... but I do not think it will be capable of enabling TPMS in you radio, so that you get the TPMS tab. BUT I could be wrong about that. With their software I can see where you enable TPMS in the BCM and Gauge Cluster, and assign the tire sensors... but no where is there anything about enabling TPMS in the radio. Calling TechnoResearch yielded no clear answer (yes or no) as to if their software could do that. I know in Diag4Bike and DigiTech its under "Radio Customizations". With TechnoResearch's software it may be part of one the other processes (enabling TPMS in the BCM or Gauge Cluster). Soooooo, if your indy is able to do that with TechnoResearch, let us know.
Once I return I'll see if my dealer will consider the BCM reprogramming/marrying to my bike. If not I'll find another indy shop with the right equipment.
Thank you for your reply and good luck with your project.
You might want to find out if a used BCM can be "re-programmed" to another bike. I do not know the answer to that.
https://www.hdforums.com/forum/milwa...1-tpms-17.html
While the guy was programming the BCM, I asked him if the BCM I took out of my bike could be put in another bike, or was it "married" to my bike. He said it should be able to be used in another bike, if somebody wanted to. He said if he was doing it using DigitTech, he'd just do "replace module" and it should work... so if you got a good used BCM, it should work. I used a new one, HD#41000341F, and all is well that route.
In the end it was quite simple, I acquired a used BCM #41000341A (I believe from a 2017 model), the latest generation of TPMS #42300124A and new FOBs, along with the right diagnostic software and a interested technician. Thanks to Rob at Detroit Choppers in Roseville, MI for seeing this thru. He used his TechnoResearch to marry the BCM to my bike and to make the necessary adjustments. TechnoResearch by the way is in Royal Oak, MI, just south of where I live. They helped me find Detroit Choppers.
I paid $150 for the use BCM and if I had to do this again, I would choose to buy a new BCM which at this time is #41000341F. I didn't save any money by buying a used BCM. So now I don't have to get down on the ground to check my tire pressure.
Thanks to everyone here that guided me thru the process. Much appreciated.
Just curious, why did you replace the FOBs? Once you get the BCM swapped out, you could have link it up with the original ones, I did.
Just for reference in case anyone reads this in the future, the guy that did my BCM swap (HD mechanic) told me I could use 1 or 2 of the "new" style or 1 or 2 of the "old" style FOBs, I just can't mix them (1 old & 1 new), so I used my original ones.
Also, after the BCM swap (required on 2014-2016 Non CVOs) be sure to get your PIN entered back in... the bike's security won't arm without a PIN entered, and it will start without the FOBS... ask me how I know... lol
Congrats!
Congrats!
When the technician swapped the BCM he was able to read the PIN from the used BCM and replace with my desired PIN. So thank you.
