Tour Pack Lighting Issues
Old Sep 24, 2014 | 08:59 PM
jpalm's Avatar
jpalm
Default Tour Pack Lighting Issues
I just mounted a 2009 tour pack on my 14 SGS. I used the factory harness that comes with the air wing luggage rack light and it plugs directly into the tour pack light and everything worked fine. So then I start the bike to take it for a spin and about ten seconds after I start it I lose all of my running lights on the tour pack and the fender. The brake lights still work all around, but no running lights. I repeated this several times and get the same results. All of the lights work fine before the bike is started and I only have this problem when the bike is running. Once I unplug the tour pack lights everything on the fender operates normally. Any idea what's going on? Solutions?
Old Sep 24, 2014 | 09:35 PM
Hammz's Avatar
Hammz
I'd say the BCM is seeing too much current draw on the TL circuit & shutting it down.
You may be able to resolve this by changing out all the incandescent bulbs for LEDs to lower current draw.
Old Sep 25, 2014 | 04:48 AM
jpalm's Avatar
jpalm
You think the BCM can be flashed to allow for the extra draw?
Old Sep 25, 2014 | 05:56 AM
Powergod's Avatar
Powergod
Had the same issue on my road glide went with led and that solved it.
Old Sep 25, 2014 | 06:08 AM
jpalm's Avatar
jpalm
Do they make a direct LED conversion for it, or do I have to look forward to hacking away at it?
Old Sep 25, 2014 | 08:26 AM
Hammz's Avatar
Hammz
No. Short of changing to LEDs, the next best solution would probably be to purchase a trailer wiring harness adapter & connect the TP through the adapter. That way the original wiring won't see the TP lighting load, but the TP lights would get the proper on/off signals & its' lighting power from the battery through the trailer harness.
Old Sep 25, 2014 | 10:33 PM
jpalm's Avatar
jpalm
Success! After looking into LED conversions to the tune of over $600, and even contemplating scrapping the whole thing and starting fresh with a 14 tour pack, I finally figured it out. My local dealer helped me as much as they could, so I can't really fault them, but in the end they were of no help. They even went so far as to call a tech at HD HQ and he said that my setup should work without a problem and that it's probably a bad ground somewhere. I had an indy look at it and he agreed that there was too much current draw and that I would have to switch to LED's. Well I figured if TOTAL current draw was the problem, then why does it have to be the TP lights that are converted to LED? So I rode up to my dealer, bought some CD LED's for the fender mounted tail lights for $65 (less than $600), installed them in the parking lot and voila! I now have running and brake lights all around. The bike was confused for a minute, but I turned on the hazards and it self-corrected.
Old Dec 19, 2014 | 06:26 PM
rodderv's Avatar
rodderv
Thank you,Thank you,Thank you.I was having the same problem
Old Dec 23, 2014 | 06:26 AM
jpalm's Avatar
jpalm
Glad I could be of assistance. The only problem with LED's paired with incandescent is that the incandescent bulbs have a very noticeable delay in activating when compared to the LED's. You may also want to look at these LED replacements for the tour pack as well. Less than $15.00. Good luck.
Old Dec 24, 2014 | 10:09 AM
rodderv's Avatar
rodderv
Ok,Will do.Thanks again everything works great!!
Born2cure
May 25, 2017 05:05 AM
Radams
Aug 18, 2014 07:42 PM
mike79
Sep 5, 2010 09:15 AM
carlosgtn
Feb 25, 2008 08:32 AM
Lil Truckr
Mar 27, 2007 10:43 AM
