Access handlebar clamp ?
Old Oct 2, 2014 | 01:59 PM
472viper's Avatar
472viper
They say the switch panel is a bit like a jigsaw puzzle, turn the bars slightly right and finagle the switch panel off through the slot in the panel.
Old Oct 2, 2014 | 02:46 PM
Jagpanzer's Avatar
Jagpanzer
Originally Posted by Afdharley
I did not remove my ignition. On the '14s the black switch cover is slotted so it will slide back out from under the ignition.
Good luck.
That's handy to know! Helps keep the forks from locking and preventing further work until you put the ignition back on and start over.
To the OP I took a little bit off of the end of my allen key so it would fit up under the dash a little easier. Rotating my bars a little forward was the best thing I've ever done. No more pain between my shoulders on long rides.
Old Oct 2, 2014 | 03:53 PM
06SGWA's Avatar
06SGWA
It's a simple process. Like they said, slide the switch plate back after removing 2 screws, loosen the two closest clamp bolts and adjust as needed. Tape on your allen is a good idea. I use the rounded head allen sockets.
jma100
2014-2024 Touring Models
Feb 18, 2019 12:13 PM
PeteF
15
Dec 28, 2016 07:57 AM
Jmbeebe0722
15
May 19, 2014 02:57 PM
Gibby13
Jul 9, 2011 05:02 AM
Irish Metal
May 21, 2009 12:36 AM
