Unlock Power Vision
Old Oct 5, 2014 | 09:48 AM
kipd's Avatar
kipd
Unlimited for any bike that you have it licence for. However you only have 6 tune save slots on the unit, so you would probably want to save tunes on your computer. When you purchase a second license you will need to provide information to them which requires you to plug the unit into the new bike and run a report that saves to the unit, you then email the file to them and they set up your new license and email it back to you. After that time, you plug the PV into your computer and save the new license file to the unit, then it can be used on either bike as needed
Old Oct 5, 2014 | 10:49 AM
rheology1's Avatar
rheology1
Cool, my dad has a 2010 UC he wants to do a stage 1 on and this will save some money.
Old Oct 5, 2014 | 01:59 PM
ke5rbd's Avatar
ke5rbd
Originally Posted by rheology1
Does this allow you unlimited use between both bikes? Is it married to both simultaneously or do you use the same unlock code every time you switch between bikes? Looking to get a second license as well.
It has full function on every bike it is locked to. Only difference is you have to share the 6 loaded custom maps slots, which is no big deal as you can use all six lots for the same bike if you like. Whichever bike you hook it to is the same procedure as it was when only using on one bike. It automatically locks to the correct bike. You only enter the unlock code once. You can hook a PV to any bike and it will do all the recording activities and reading DTC's and monitor all gauges. It will not make any change to the bike unless it was locked to the bike.
Socalledchad
Oct 6, 2018 09:01 PM
epd612
Touring Parts
Jul 26, 2012 02:30 PM
geo08nightster
Mar 25, 2009 07:03 PM
sifularson
Nov 9, 2008 12:07 PM
RBJones
Mar 24, 2006 07:47 PM
