EITMS active below 80
Old Oct 29, 2014 | 11:42 PM
hanny's Avatar
hanny
Originally Posted by SafetyMan
If it did, your bike has some major failures.... like 5 of them. Take it in for warranty work.
actually it only had one problem. the injector stayed off, lol. now its Not a fuel injector issue actually but the computer keeping it off. WHY????
WELL, as a master auto technician for 20 years with an in depth diagnostic back ground I could assume what it is,,, and its an individual issue. Ive worked on everything you could imagine and cars with 8 computers and up to around 90 sensors. So the Harley and its 8 sensors or so is really a pretty basic fuel injection system to diagnose. That said its not 5 problems its just the one I had one,,,,,,,,,, what was my issue you might ask? It could be only one thing,,,,,,,,,,,,,,,,,,,,,
Old Oct 30, 2014 | 11:51 AM
SafetyMan's Avatar
SafetyMan
It's that simple.
I've been in oil and gas for 20 years, I Frac. I've got hundreds of sensors, gauges, transducers and densiometers running numerous computers, monitoring fluid rates, chemical rates, dry rates, density, pressure, proppant rates, and the last time my safety adviser pooped. A lot of which are regulated by the USNRC, yes Nuclear. I control twenty 2000hp pumps in a central control van, along with blenders and hydration units and have wrenched on everything from a 2hp single cylinder generator to a 2200hp 16v diesel engine, to pumps that put out over 100bpm at 15,000psi....
Still boils down to, you've got a 2014 that doesn't function properly.
Take it in for warranty work. It is that simple.
I have lots of tools too....
Old Oct 30, 2014 | 11:54 AM
my67pnycar's Avatar
my67pnycar
Old Oct 30, 2014 | 01:31 PM
Howler_LI's Avatar
Howler_LI
Originally Posted by Greg2012FLHTK
Check to see what the bike shows the temperature as. Mine has shown 80 even though the actual temperature was around 70. I think that happens when the sun shines on the fairing and heats it up.
>It also has activated a number of times with air temps at 73, even 63 degrees.<
I quoted the temps shown by the bike which seemed to reflect the actual ambient air temp pretty well. Having the EITMS kick on at 63 was a surprise, except that the engine was throwing a lot of heat.
Basically I'm wondering if the owners manual, Bulletin M-1351 (thanks 14 GuineaPig !), etc. don't tell the whole story, if there is another reason for rear cylinder deactivation.
Old Oct 30, 2014 | 02:59 PM
nicliv's Avatar
nicliv
Originally Posted by my67pnycar
Congrats!! You made it home, Brother. Now enjoy what we served for.
Old Oct 30, 2014 | 03:05 PM
my67pnycar's Avatar
my67pnycar
Thx Brother. Hope you are home and safe to. Been home over a year now,lol. I just picked up my second retirement present, see sig pic, hehe. 1st retirement was Big Red, my 2011 limited, they gave me a smoking deal, so I traded.
Old Nov 1, 2014 | 03:17 PM
ultramotive's Avatar
ultramotive
I just noticed that the Owner's manual does not say anything about the AAT relative to the EITMS. It only refers to engine temp. So there appears to be a contradiction. Perhaps the Service Bulletin overrides the manual but if so it should state that. It would appear mine works as the manual states, though I have no way to know the engine temperature but every time it activated it was quite hot. Like I said previously mine has kicked on twice below 75F.
I spoke to a nearby dealer and they thought it was engine temp not air temp.
Old Nov 1, 2014 | 09:31 PM
Hammz's Avatar
Hammz
It's that simple.
Don't think he has a warranty....
He cut the neck on the frame, etc, etc.
Saw a couple threads that mentioned ECM updates due to separate spark tables now for air cooled vs water cooled models. Might be the ECM still has the 288 degree engine temp que in the control loop as well as the AAT? Just a thought...
Old Nov 1, 2014 | 11:10 PM
SafetyMan's Avatar
SafetyMan
I missed that.
You may be right.
Old Nov 2, 2014 | 06:55 AM
Howler_LI's Avatar
Howler_LI
That would explain my experience.
Where is the Engine Temperature Sensor? i.e. of what exactly does it measure the temperature ?
