Questions about installing new bars
Did you use\have the service manual? I don't have one so was there anything in there that really helped you or you couldn't have done the job without?
Do you need to cut power? if so did you do this by pulling a fuse or unhook battery leads?
Last question is about removing and installing the switch housings.
I started to take apart the housing and it did not seem to just come apart easy. again any trick or tips for removing the switch housing and clutch and break levers?
Pics of an install in this thread.
https://www.hdforums.com/forum/new-r...-included.html
Yes I would cut power by pulling the main fuse.
I did not have a manual at the time, there is a lot of info in the forum (search it), i do have a manual now thou lol
I did not, but it would be wise-pull the fuse.
You do not need to remove the main ignition switch just remove the cover.
there are great threads on this subject, this one has great pics:
https://www.hdforums.com/g/album/1569526
You will need (69200034 Switch Wire Extension Kit) about $30 at dealer. good luck, have fun, get to know your bike
I changed mine out using just the thread quoted above. The dealer was out of manuals and I didn't want to wait. That thread is excellent, with good pictures. It took just under 4 hours, including clean up time for the parts before reinstallation.
I would have appreciated a video when I was searching info as you are. Good luck
