1.18.3 Discovery
Old Feb 12, 2015 | 12:39 PM
FinalShot's Avatar
FinalShot
Originally Posted by Yukon42
Well at least you guys get the Nav to come up. I push the hard button and all I get is a compass. Tried toggling to the menu button and same thing. Go figure. Well, back to the shop it goes.
Have you tried the hard reset yet? Maybe the base maps are missing?
Old Feb 12, 2015 | 02:13 PM
Yukon42's Avatar
Yukon42
No didn't try a hard reset. It's going to the shop in a few hours so we'll see what the tech does. Well even if the basemaps weren't there at least you should be able to get some type of gps menu items don't ya think? It's acting like there is NO gps installed at all.
Old Feb 12, 2015 | 09:56 PM
Schoondog's Avatar
Schoondog
I will just be happy the dimming issue is gone. Downloading right now. They need to have an email list for everytime they have an upgrade.
Old Feb 13, 2015 | 05:40 PM
Yukon42's Avatar
Yukon42
Shop was able to fix the no gps problem I was experiencing. Apparently it wasn't properly initialized when they installed it. Pretty easy fix.
Old Feb 13, 2015 | 07:14 PM
surfrat2's Avatar
surfrat2
Originally Posted by 14cvoultra
Mine also defaulted to Canada. It seems to be fixed
but I have not had a lot of time to test it. I also for the first time have been able to import a route that I built that has about 50 waypoints and 3 stops VA to Austin TX when I select it and hit go it appears to load correctly it also appears correct on the map screen. This is the site I used to make the route
https://www.myscenicdrives.com/road-trip-planner
How do you import a route to the Bikes computer?
Old Feb 14, 2015 | 08:13 AM
Schoondog's Avatar
Schoondog
Default You have to download it.
Go to harley website and build a route. Download the GPX file onto a thumb drive. With the new update it says you can go 100 waypoints although I haven't tried. Go into the sub menu on the NAV and you should be able to load route. I thought I had already done a tutorial video for this but I can't find it.
Old Feb 14, 2015 | 10:15 AM
FinalShot's Avatar
FinalShot
Use your favorite mapping software. I use Tyre, Basecamp and HD Ride Planner and these all work.
Build your route with your software
Add enough way points to create the route you want to follow
Save/export the file as a GPX
Copy it to a usb drive
On your bike, go to
Navigation---Menu---Import
Once on the import screen, you will see your route(s).
Select your route and then cursor over to the import in the middle
When it is done reading the gpx file (could take 30 or more seconds) Only select the name of your file, do not select all or any of the other way points
It will import your route and bring you back to the import screen.
Go to Nav---Where To---More---Trips
In the trips, select the trip you imported, then select Start
This will guide you to your next way point on the list and so on.
Old Feb 14, 2015 | 09:32 PM
FinalShot's Avatar
FinalShot
I created a video showing how to do it: https://www.hdforums.com/forum/new-r...n-to-boom.html
On your bike, go to
Old Feb 15, 2015 | 08:20 AM
surfrat2's Avatar
surfrat2
Perfect! Thanks guys...one more question, can i use the same thumb drive that i use for the software update?
Old Feb 15, 2015 | 08:25 AM
Howler_LI's Avatar
Howler_LI
You'll need to delete the update files first, or it will try to install again.
There is no need to keep a backup of the install files, the originals are on Harley's site.
