spark plugs
Old May 12, 2015 | 08:37 PM
joenash's Avatar
joenash
Originally Posted by FinalShot
That's true, I had forgotten about that. It can cause over torquing of the plugs.
Originally Posted by AZdryheat
Note that NGK says NOT to use anti-seize on their spark plugs.
Originally Posted by namojom
"Oh and how do you put anti-seize in between two pieces of metal that you want to conduct electricity ?"
I'm not understanding this statement. Anti-seize has copper, zinc, graphite and aluminum in it, all excellent conductors of electricity?
Weather I am wrong or not about the excelent conductivity of anti-seize.
Their are two reasons that are noted in this post NGK the spark plug manufactor of the plugs says not to . And anti-seize can cause over tourquing.
I always thought if the threads were clean their was no need for anti-seize.
Old May 12, 2015 | 08:49 PM
Cool Inferno's Avatar
Cool Inferno
It's not just that they have to be clean. They seize because of corrosion of the metals and or the break down of the metals because of the heat cycles they go through. Happens more frequently with cheap plugs.
Old May 12, 2015 | 08:53 PM
joenash's Avatar
joenash
I thought it was because of the two dissimular types of metal, aluminum head metal spark plug, ? maybe NGK has better material ?
Old May 12, 2015 | 08:56 PM
Cool Inferno
Well its like they always say "you get what you pay for"
Old May 12, 2015 | 09:51 PM
namojom's Avatar
namojom
2014 touring service manual, 2nd step under installing spark plugs says,
"Apply anti-seize lubricant to spark plug threads. Tighten to 12-18 ft-lbs."
Old May 12, 2015 | 10:16 PM
joenash's Avatar
joenash
Maybe that is why harley does not want to use NGK Plugs. I thought the harley plugs were made by champion, but to harley specs ?
Found this online
http://www.ngksparkplugs.com/pdf/dyk_5points.pdf
Old May 12, 2015 | 10:32 PM
joenash's Avatar
joenash
Default found this on the internet!!!!!
Found this online --so it must be true!!!!!!
NGK recommends:
"Do not use anti-seize. Anti-seize reduces electrical and thermal conductivity between the spark plug and head; and increases the installed torque, which can damage head threads. The spark plug holes must always be cleaned prior to installation, or you may be torquing against dirt or debris and the spark plug may actually end up under-torqued (dry threads), even though your torque wrench says otherwise.
All NGK Spark Plugs are manufactured with special shell plating on the metal body. The use of anti-seize on spark plugs is only recommended on those brands that do not offer a special metal shell plating. Install spark plugs with a compression gasket finger tight until seated and then turn approximately 1/2 to 2/3 turns. Spark plugs without a compression gasket (taper) should be installed finger tight until seated and then turn 1/16 turns.
Racing Spark Plug Installation:
Do not use anti-seize. To install spark plugs in the engine, first tighten them by fingers, then retighten with the right tightening torques as shown below, using a plug wrench. Either excessive tightness or looseness will cause troubles. Looseness sometimes causes pre-ignition because heat cannot disperse. On the other hand, excessive tightness can damage the threads of both the cylinder head and the spark plug."
Champion recommends:
"Champion recommends that you do not use an anti-seize compound, since one has already been applied to the plugs at the factory. Next, install the spark plugs finger tight and, if using a taper seat spark plug, use a ratchet to rotate 1/16 of a turn. If using a gasket seat type spark plug, after installing finger tight, turn 1/4 to 5/8 of a turn. If this procedure is followed, spark plugs will not back out nor will they seize in the cylinder head."
Autolite recommends:
"We do not recommend anti-seize. Install 14mm plugs in aluminum cylinder head at 20-30 Nm (15 - 22 foot pounds) with CLEAN and DRY threads. We do not recommend the use of any anti-seize products for installing spark plugs. Anti-seize compounds are typically composed of metallic, electrically conductive ingredients. If anti-seize compounds come in contact with the core nose of the plugs, it can lead to a misfire condition.
Anti-seize on the threads of your spark plugs will slow down the rate of heat transfer from the plug to the head. The worst place to use it is on the tapered seat, which is where the most heat transfer occurs between the spark plug and the cylinder head. Even just a small amount of anti-seize is the equivalent of using a hotter heat range spark plug.
Anti seize compounds can also have a torque multiplying effect when installing plugs. This can lead to thread distortion and thread galling resulting in cylinder head damage. Autolite spark plugs are nickel plated to resist the effects of corrosion and seizing.
NOTE: Spark plugs should be installed with clean and dry threads to avoid over-torquing or stretching the spark plug, which can, and often does, result in engine damage."
Denso recommends:
"Do not use anti-seize. Installation Key Points: (1) The threaded area of the cylinder head must be clean. (2) Using your fingers, screw the spark plug into the cylinder head, and tighten about 1/4-1/2 turn with a plug wrench. (Taper seat plug: about 1/16 turn). (3) Tightening too much may cause distortion of the plug housing, and in extreme cases could cause engine damage. Proper installation of the spark plug is important for life and performance of the spark plug. (4) Installation procedures shown above apply to new spark plugs without lubricating the threads.
Torque Recommendations (dry threads). Whenever possible it is recommended that the spark plug should be installed by using a torque wrench. "
Bosch recommends:
"Do not use anti-seize. Bosch small engine spark plugs are constructed with a nickel chromium ground electrode for consistent performance and prolonged service life; Nickel-plated rolled threads offer complete anti-seize and corrosion protection. Built to withstand extreme operating temperatures and give more power, Bosch Super Start is ideal for all small engine applications."
bicard
Milwaukee Eight (M8)
29
Apr 21, 2018 08:28 AM
peg20
Dec 15, 2015 03:34 PM
Kevin Robinson
Aug 15, 2015 06:30 PM
1stHD_95FXDWG
Apr 26, 2014 07:40 AM
corona
Exhaust System Topics
Mar 5, 2007 08:34 PM
