Boom update
Old Mar 16, 2015 | 03:57 PM
95ci springer's Avatar
95ci springer
Default Boom update
I plugged the thumb drive into the radio port to update to 1.18.3 and it says its reading the USB but I don't get prompted to do anything and its not updating. Please help!
Old Mar 16, 2015 | 04:09 PM
RonaldNC's Avatar
RonaldNC
Make sure that the swdl_boombox_6.5GT.iso file is in the root directory of the thumb drive and that you have nothing else there. Also, make sure your thumb drive is formatted as FAT32.
Good luck!
Old Mar 16, 2015 | 04:12 PM
95ci springer
I have no idea what a root directory or fat32 is. I'm deleting and retranfering to the thumb drive right now.
Old Mar 16, 2015 | 04:16 PM
RonaldNC's Avatar
RonaldNC
If you're using Windows, chances are that it will be formatted in FAT32. Just make sure that when you look at the file contents of USB drive on your computer, that the .iso file is in the highest (root) directory. If you still have troubles, I'll work to send you a picture of what the files should look like.
Old Mar 16, 2015 | 04:18 PM
milleda31's Avatar
milleda31
Plug in thumb drive
Delete anything on it
Right click on thumb drive icon in windows explorer
Format (select fat32)
Load Boom update ISO image
Plug thumb drive into Hog
Old Mar 16, 2015 | 04:23 PM
95ci springer
I'm now getting errors tranfering the update.
Old Mar 16, 2015 | 04:24 PM
95ci springer
And yes, it's fat32 by default.
Old Mar 16, 2015 | 04:25 PM
95ci springer
I believe its in NTI iso file.
Old Mar 16, 2015 | 05:16 PM
J929626's Avatar
J929626
When plugged into our computer the USB drive will have a drive letter associated with it. In Windows Explorer, doubble click that drive letter to open up the USB drive.
The only file on the USB drive should be named "swdl_boombox_6.5GT.iso". If the file is named "swdl_boombox_6.5GT.1.18.3.zip" then you have not un-zipped the file that you downloaded. Double click on the .zip file to open it, copy the .iso file back to the USB drive and then delete the .zip file.
The update should then work.
Old Mar 16, 2015 | 08:21 PM
95ci springer
I'm getting errors. I can't unzip it.
