2014 Limited Turn Signal Indicators Fast Flashing...
Old Dec 20, 2019 | 12:36 PM
offthewall's Avatar
offthewall
Originally Posted by Lancemchn
I've already done the searching and tried all the fixes I found but still have fast-flashing indicators on the inner fairing when using the turn signals.
Here's my set-up:
Removable tourpak, CD Dynamic Ringz up front (white/amber), saddlebag spoiler signals, HD lay-down LED brake light and Kury plate frame w/ LED illumination in the rear. All functions work properly when the TP is on but when removed I get the fast-flash indicators.
I've tried holding the trip button, turn ignition on, run switch and then hazards.
I've tried ACC and flashers for up to 10 minutes multiple times.
I've tried IGN and flashers for up to 10 minutes multiple times.
I'm at a loss... I've kinda gotten used to not noticing the indicators flashing fast but would like to get this right. Are there any other tricks y'all have tried? Everything works fine when I have the TP on with the same set-up.
How old are the CD Ringz? I had an early set that did the same thing. I replaced them with newer ones and problem solved. Also anytime you change lights, you must run the 4-way flashers for about a min to reset the computer so that you don't get the fast flash.
2deuceguy
EVO
Feb 5, 2016 10:36 PM
Brazeal
Electrical/Lighting/Alarm
Apr 23, 2015 11:59 AM
CJinNH
Aug 11, 2014 09:26 AM
Primo
Oct 18, 2007 10:07 PM
06king
Jan 25, 2007 12:52 AM
