detach power vision cable?
Old Apr 5, 2015 | 01:24 PM
azbob09's Avatar
azbob09
Default detach power vision cable?
What's the trick to get the power vision cable disconnected from the power vision unit?
Old Apr 5, 2015 | 01:39 PM
8828alex's Avatar
8828alex
you will see a little push tab on back of wire connector , push it in and pull wire out of unit . you may need both hands.
Old Apr 5, 2015 | 05:05 PM
Ganooch's Avatar
Ganooch
Strange. Maybe it is because I have the PV2, but my cable has no tab. It just pops right out.
Old Apr 5, 2015 | 05:27 PM
nsdhoward45's Avatar
nsdhoward45
PUT YOUR GLASSES ON SO YOU CAN SEE THE RELEASE TAB im not yelling i just want you to be able to see this
Old Apr 5, 2015 | 06:26 PM
azbob09's Avatar
azbob09
I have my glass on but I still can't seem to push that little tab (I/16 to 1/8) on the back in right below where cable enters unit? Even tried a small screw driver to push in with. Last thing I want is to break it...
Old Apr 5, 2015 | 06:38 PM
sixguns's Avatar
sixguns
are you pushing on the right end of the lock tab?
Old Apr 5, 2015 | 08:27 PM
Vernal's Avatar
Vernal
Default Release Tab
Push down where I put a little orange paint on the tab. Look at the close up of the PV and you will see a little raised area the tab needs to clear to pull it back.
Attached Thumbnails detach power vision cable?-img_6309.jpg   detach power vision cable?-img_6312.jpg   detach power vision cable?-img_6311.jpg   detach power vision cable?-img_6313.jpg
Old Apr 5, 2015 | 09:53 PM
goose222's Avatar
goose222
Mine does not have the tab either and it was purchased two months ago.
Old Apr 6, 2015 | 06:55 PM
azbob09's Avatar
azbob09
Thanks for taking the time & the great explaination...
Romley
Sep 5, 2016 07:53 PM
Cull22420
Mar 1, 2016 07:09 PM
iamtylerdurden
Sep 3, 2013 07:17 PM
ms3300
Detailing
Jan 13, 2010 06:39 PM
Roadking Cal
Jan 1, 2010 02:09 PM
