Trying to install the daymaker fog lights (not passing lamps, the new crash bar fog lights) on my 14 SG. Dealership not a lot of help as far as figuring out which wiring harness and switch it requires. Anyone installed these any part numbers or tips would be great.
Mine's in the shop now for this install. Don't have p/n's here, but when I pick it up Saturday, the paperwork should have the parts listed. Had mine installed via harness to the under seat aux connection. Added a new pushbutton latching switch with the green led indicator (same switch as used for the oe fogs, added to right of oe switch, center position on left bank of 3). No program changes were required of the BCM to make this work.
Thanks for all the input. Finally got mine working after a gazillion different tries and wires. I used 69201109 wire harness plugged into right turn signal, and 69200172 switch that plugs directly into oe wires under blank switch on left of fork lock switch.
Looks good, how much light to the road, turning, out to the side do they add?
Haven't ridden it after dark yet. Did notice they throw a very flat beam, mounted as mine are they throw vertical beam of light. Will be relocating them, they were supposed to be mounted on the outside vertical bars. Found it hard to hide wires in doing such. Will take and post some pictures after dark once I relocate them.
Would like to see a picture or two of how the dealer hid or positioned your wires once you get it back. Also where they positioned the lights. Thanks
