Using the kill switch - mandatory?
Old Apr 13, 2015 | 02:42 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Probably good to know where that thing is if a clutch hydraulic failure occurred.
Old Apr 13, 2015 | 04:00 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by ultraclassic53
Only reason I can think of for going straight to the main switch is lights...... There has been plenty of times I hit the kill switch then got distracted and forgot to turn the main . My friends like to make sure I'm about as far as possible from the bike before they point it out and make me all the way back to turn it off
Dude if you can get 3 steps away from your bike without looking back at it...
....you bought the wrong bike!
Old Apr 13, 2015 | 04:21 PM
Sam2010's Avatar
Sam2010
Zero throttle position was fixed from 2010 on. I'm a kill switch user I don't know about can bus system but I recall a argument that switched by kill switch as instructions described you were switching less electrical load. I'm just repeating something I read just for the sake of argument.
Originally Posted by SafetyMan
By ALWAYS using the kill switch, you develop a habit, and muscle memory.
From a SAFETY standpoint, it is better to kill the engine there, if there is ever an emergency that you need to shut the engine down fast, you won't have to take your hands off the bars or think about it.
The only drawback, and they may have fixed it by now, is if your hand has the throttle slightly turned, can cause the ECM to get confused, and begin idling higher. If you are sure to have the throttle at zero, there are no issues.
From a mechanical standpoint, you are not going to hurt anything by using the ignition switch.
Old Apr 13, 2015 | 04:35 PM
Just Me's Avatar
Just Me
OMG! What's the matter, is it too hard on your thumb? Next thing you know you will want an automatic kick stand.
Come'on its spring, get out and ride instead of dreaming up stupid threads!
Old Apr 13, 2015 | 06:01 PM
RG Pilot's Avatar
RG Pilot
Well all righty then! Easy to get some people fired up I guess...
Old Apr 13, 2015 | 06:39 PM
FinalShot's Avatar
FinalShot
As other's have said, this topic has been beaten to death. Like other CVO owners, I don't have anything but a kill switch. The switch on my forks is just a fork lock and that is it.
Old Apr 13, 2015 | 07:06 PM
Roadie09's Avatar
Roadie09
I have used the main switch and the thumb switch to shut off my 2009 and the 2015. There have not been any issues with the bikes from shutting them down. I am sure there are some small load issues by shutting down in a certain order, but it is not like we are powering down a reactor. I just use whichever switch my hand is closest to when it is time to cut it off.
Old Apr 13, 2015 | 07:13 PM
IdahoHacker's Avatar
IdahoHacker
Main ignition switch. No reason to use the kill switch. At all.
Old Apr 13, 2015 | 07:16 PM
Aubert's Avatar
Aubert
Originally Posted by Ron750
Here are 19 threads on kill switches:
https://www.hdforums.com/forum/searc...rchid=28978220
I looked through some of the threads, and the only rational reason I saw for using the kill switch, is that you are covering the brake and clutch, when you use it. So it is a little safer than taking your hand off to kill with ignition switch.
I just kill switch out of habit.
I bet that's it, just something the consider to be safer. When I took the MSF course in 2012, they constantly urged us to use the kill switch.
Old Apr 13, 2015 | 07:21 PM
ssrgeoff's Avatar
ssrgeoff
Originally Posted by woodmnctry
I a kill switch kinda guy --- so much in fact that I have managed to use that switch when actually going for the turn signal --- great fun!
^ This... haha.
