road king slip ons
Old May 10, 2015 | 09:37 PM
handyman639's Avatar
handyman639
Default road king slip ons
thinking of getting LA Chopper slip ons, sounds good and deep. SE Big sucker air system and a dyno. Any comments appreciated. Thanks in advance. I have a 2014 Road King
Old May 11, 2015 | 01:01 PM
Ridewva's Avatar
Ridewva
I don't know anything about Chopper slip-ons but if that's the sound you want go for it. A dyno tune seems kind of overkill just for mufflers and intake when there are now some very effective devices (FP3, Power Vision, etc.) that'll get your bike dialed in.
Old May 11, 2015 | 02:32 PM
GPHDXLC's Avatar
GPHDXLC
What kind of tuner do you have now?
Old May 11, 2015 | 03:19 PM
Magnut1's Avatar
Magnut1
Yeah , what Ridewva said. If you are going with a certain intake and certain mufflers, chances are, the companies have already developed a MAP for that combo. So you won't have to pay for something someone already did. If not, and you are mix matching, chances you will get close with a stamped map. If you are going with a custom combo, like bigger throttle body, bigger cams, head work, you are sticking in thousands and then you would probably want to know what the numbers are.
If you are going to change things here and there in the future, then I would suggest something like Thundermax with Autotune that will keep up with all the changes. You spend $350 on a good dyno now, then add cams, another dyno, add throttle body, another dyno, heads, dyno. Keep that all in prospective.
My combo is Kuryaken Velociraptor AC, Rinehart true duals, and Thundermax. It is fast and lots of power. No dyno for me. But if I change anything, the auto-tune feature will just adapt. Hope that helps.
Old May 11, 2015 | 03:27 PM
handyman639
Everything is just stock, can't do true duals right now. Will look into what is suggested. Thanks
Old May 11, 2015 | 04:03 PM
SafetyMan's Avatar
SafetyMan
A dyno tune will almost always net better results than a canned map, or even a canned map and some auto tune runs.
But.
You and you alone have to decide if it's worth the added cost.
Me... I'm not looking for thousandths running the drag strip, nor "paper racing" with my buddies dyno sheets, so I don't see it necessary.
My bike runs great with the PV2, Jamie's map, and 4 or 5 auto tune sessions.
IMHO, the rider's skill makes up the difference.
The good thing with a PV2, TTS or FP3, if you decide to make changes down the road, you're ready.
Old May 11, 2015 | 07:14 PM
MikeZ's Avatar
MikeZ
You need to change your head pipes or you're wasting your money.
phananganang
Sep 29, 2013 11:24 PM
bpav16
Exhaust System Topics
Oct 6, 2012 08:29 AM
EdwardK
Oct 11, 2011 01:16 AM
PistonPuller
Oct 30, 2010 06:20 PM
patriotmc
Jan 18, 2010 07:22 PM
