Cap for CB antenna post
Old Jun 12, 2015 | 07:20 AM
indiggio's Avatar
indiggio
Originally Posted by WG2011
Why would one need to cap this? If you buy the rubber grommet like the opposite side has it cover the hole completely. I guess it could rust if you ride a lot in the rain?
Right now the CB antenna side has what looks like a threaded hole where any water could collect and eventually rust.
I suspect the CB antenna base probably has a short, threaded rod exposed to screw into the hole on the tour pack.
My plan would be to take a screw the same size as that on the CB antenna base, cut off the head of the screw and put that into the hole and then put one of these vacuum caps over top of the screw.
Old Jun 12, 2015 | 01:15 PM
dukdog's Avatar
dukdog
I inspected the post and found what looked like a very small hex socket. I did not take out the tour pack liner to see if maybe there is a jam nut on the other side. I picked up a pack of assorted size vacuum caps today and will put on the post tonight. Believe I'll put a little dielectric grease on the post before hand.
Old Jun 12, 2015 | 03:04 PM
Punjabi Rider's Avatar
Punjabi Rider
Just take your antenna to Ace store they will figure out the rest .
Old Jun 12, 2015 | 03:16 PM
indiggio's Avatar
indiggio
Yeah, therein lies the problem.
I don't have the antenna...
Old Jun 12, 2015 | 03:22 PM
Hammz's Avatar
Hammz
?? A 2015 Limited comes with the CB antenna & the AM/FM antenna. You no longer have either antenna? They both use the same size threads...
Old Jun 13, 2015 | 05:56 AM
indiggio's Avatar
indiggio
Yeah, not worth getting into...
Suffice to say, I didn't buy bike new.
Thanks!
Old Jun 15, 2015 | 10:15 AM
indiggio's Avatar
indiggio
Stopped by the dealer yesterday.
Turns out HD makes a short (about 1" long) threaded rod that fits into the base on the tour pack where the CB antenna would go.
All I need now is to get another vacuum cap that matches other side and I'm good.
Thanks!
Old Jun 15, 2015 | 10:36 AM
MikeyTX's Avatar
MikeyTX
The hole for the right and left side is 5/16". I simply removed both of the threaded assemblies from the bike. I have a short rubber duck antenna installed the the am/fm side cable inside the tour pack laying horizontal. Works great and I'm in the boonies almost 50 miles south of Dallas, TX.
Old Jun 15, 2015 | 10:46 AM
BoonDock_Saint's Avatar
BoonDock_Saint
You could use a vacuum cap from the auto parts store. I took the right diameter heat shrink tube, cut a piece with a little extra, cut a round (more or less)piece, put it inside the tube on the top and shrunk it together. Molded it with my finger as it was shrinking. it looks like a cap.
Old Jun 17, 2015 | 11:01 PM
p51bombay's Avatar
p51bombay
Take the liner out, unplug it and remove the whole thing - fill the hole with a 5/16 plug and some clear silicone.
