Cap for CB antenna post
Old Jun 11, 2015 | 04:33 PM
dukdog's Avatar
dukdog
Default Cap for CB antenna post
I've removed the FM and CB whips from my tour pack and replaced the FM antenna with a shorty. I would like to cap the CB antenna post as I don't anticipate ever using that function. Has anyone else done this and what did you use to cap the threaded post. Thanks in advance.
Old Jun 11, 2015 | 05:38 PM
ShoreRider's Avatar
ShoreRider
Subscribed. Looking for the same thing for my Low where I pulled the FM antenna
Old Jun 11, 2015 | 06:24 PM
ACLazer's Avatar
ACLazer
Just a rubber vacuum cap like these.
http://www.summitracing.com/parts/rn...FQuMaQodZqsAQA
Old Jun 11, 2015 | 06:30 PM
brokefootkenny's Avatar
brokefootkenny
i dont have he cb on my ultra classic and there is a little black plug in the spot where the antenna would go. maybe ask the dealer? im guessing you would need to remove the threaded post.
Old Jun 11, 2015 | 07:47 PM
dukdog's Avatar
dukdog
Thank you sir. Just the solution that I was looking for.
Old Jun 11, 2015 | 09:32 PM
ACLazer's Avatar
ACLazer
Your welcome, just go to NAPA or PepBoys, and they will have them
Old Jun 12, 2015 | 03:49 AM
PRrdglide's Avatar
PRrdglide
Chrome acorn nuts from ace hardware store.
Old Jun 12, 2015 | 06:37 AM
IUOE ROB's Avatar
IUOE ROB
Didn't know that, thanks! I lost one of those antenna caps in a friends trailer, I went to Lowe's and bought those hooks that hang on a pegboard, they had the little black caps on them. Took the cap off and with a little tape under it fit pretty good on the antenna. I'll have to get a pack of these caps for the next time...
Old Jun 12, 2015 | 06:50 AM
indiggio's Avatar
indiggio
Anyone know the screw size for the CB antenna hole (I don't have the antenna to check)?
It sounds like I need to put a screw in there with the head cut off and capped with one of these vacuum caps over the end of the screw.
Thanks!
Old Jun 12, 2015 | 07:09 AM
WG2011's Avatar
WG2011
Why would one need to cap this? If you buy the rubber grommet like the opposite side has it cover the hole completely. I guess it could rust if you ride a lot in the rain?
