JW Speaker Daymaker Version II
Old Mar 20, 2016 | 03:59 PM
  #71
vhmike73's Avatar
vhmike73
Originally Posted by DAKSY
Ok. Installed the new lamp & harness yesterday & took a ride. I didn't make any adjustments, just re-mounted it in situ. On the way home, the width of the beam at low seemed to be better, & the width of the high-beam was noticeably wider. The BIG test was twisty road I live on. The 90 degree bend was SCARY with the OEM lamp. MUCH better. Probably added 35 - 40 feet to my vision thru the turn. The factory spec is 35" high at 16', according to the service writer at the local dealer. I will set it there & re-ride the corner after dark. If re-adjustment is needed, I will try to bring it up 1/2" at a time, until it's right for me.
How did your adjustments work out for adding "through the turn" visibility?
Also, is there a MARKED or noticeable difference in the High Beam on this light? I have the Daymaker Reflector on my Street Glide with matching passing lamps, and my high beam only puts a hot-spot out about 20-30 feet in front of the bike; to the point that I ride with the high beam on ALL the time and never get flashed. Just wondering if there is enough difference to make me want to switch.
Old Mar 20, 2016 | 05:48 PM
  #72
Martck29's Avatar
Martck29
Just purchased the evo 2. Haven't got it on yet. Hopefully next weekend. Hoping its better than the daymaker.
Old Mar 20, 2016 | 05:52 PM
  #73
hbsoldier3's Avatar
hbsoldier3
Did you get the HD harness?
Old Mar 20, 2016 | 05:54 PM
  #74
Martck29's Avatar
Martck29
Yes. How hard are these to install? Don't have to be a rocket scientist do you?
Old Mar 20, 2016 | 05:56 PM
  #75
hbsoldier3's Avatar
hbsoldier3
No, it is plug and play, self explanatory once you get going.
Old Mar 20, 2016 | 05:59 PM
  #76
Martck29's Avatar
Martck29
Great. I'm great at putting people's bones back together but so so with mechanical stuff.
Old Mar 20, 2016 | 06:17 PM
  #77
nightrain116's Avatar
nightrain116
Default Adaptive CORNERING light
MOCO had this light mounted in a new Street Glide. When you lean the bike over the outside leds light the corner up!!!!
Will let you know once my bike is back together from the rest of the mods. This is also from JW. 8790 model
Attached Thumbnails JW Speaker Daymaker Version II-product-photo-model-8790-1-1200x1200.jpg
Old Apr 3, 2016 | 06:27 PM
  #78
upstaterider's Avatar
upstaterider
1st Gear
Default Harness?
I see some people talking about a harness. When I go to the website they refer to this only fitting a Jeep, is there a harness to make it work on a bike? And also they do not have any running/highway lights listed on their site, do you have to but them from someone else?
Old Apr 4, 2016 | 08:57 AM
  #79
DAKSY's Avatar
DAKSY
I've got the lamp adjusted to the 35" height at 16' that the tech told me, but I haven't had the chance to ride at night yet. I bet I brought the beam UP 6 or 7" to get to 35"...Now we're in the middle of blizzard-like conditions, so I don't know WHEN I'll get to ride in the dark again. I WILL report back when I do.
Old Apr 4, 2016 | 09:00 AM
  #80
DAKSY's Avatar
DAKSY
[QUOTE=upstaterider;15005946]I see some people talking about a harness. When I go to the website they refer to this only fitting a Jeep, is there a harness to make it work on a bike? QUOTE]
See post #46...It's a Harley part
tcatnat
Jan 31, 2019 01:09 PM
truckerdave
Electrical/Lighting/Alarm
Jan 14, 2019 12:30 PM
gchalifo
Sep 2, 2015 12:46 PM
MisterPX
Great Lakes
Mar 27, 2011 04:50 PM
joflewbyu2
Nov 28, 2010 10:18 AM
