Slip-ons worth it?
Old Jun 28, 2015 | 08:29 AM
CSMHOG's Avatar
CSMHOG
Originally Posted by SafetyMan
...but there is a reason I won't buy a used bike as my primary ride...
You hit that nail on the head!! I'll only buy a used bike if I'm planning to rebuild the engine.
Old Jun 28, 2015 | 03:09 PM
wedjim's Avatar
wedjim
Changing your slip on and even many air cleaners won't, "cause your engine to run lean." More serious mods that effect air flow enough to push the fuel trim capabilities outside their limitations will cause issues though. Newer bikes with fuel injection have fuel trim capabilities from -25% to +25% so a simple slip on upgrade won't cause any issues.
Changing valve timing(cams), exhaust pipe diameter, from connected pipes to true duals, or serious engine mods, always require remapping since the fuel trim will easily exceed base trim capability limits.
BCass53
Exhaust System Topics
Aug 13, 2015 04:35 PM
smokinfromshootin
May 30, 2015 12:11 PM
BKSinAZ
May 11, 2015 02:42 PM
btharris24
Feb 11, 2014 07:21 PM
Lowrider103
Jun 22, 2013 08:27 AM
