Slip-ons worth it?
Or rather, don't get what you don't pay for.
Cheap = cheap.
If I've posted it once, I bet I've posted it 43 times...
The FIRST thing a man should do when considering making changes is GET A TUNER. It will help a stock bike, and when you change pipes and or air cleaner, you're ready for it.
Can you run without a tuner? Yes.
Will you blow your engine up running without a tuner? Probably not.
Can you expect to get 50,000 miles out of your engine without a tuner? Most likely.
Will it run correctly without a tuner? No.
Dealers and their parts and service departments are a business, in business to sell motorcycles, and motorcycle parts and accessories. They tell you that you can get away without a tuner, because a LOT of guys won't come off the jack for a tuner, and they're afraid they'll lose sales if they tell you to get a tuner.
Changing the air flow without changing the VE tables is not beneficial. These bikes run lean from the factory, adding a more free flowing exhaust makes them run more lean.
Do what you want, I won't criticize, just trying to offer things to think about.
...but there is a reason I won't buy a used bike as my primary ride...
Here's the thread
https://www.hdforums.com/forum/softa...confirmed.html
If you're looking for more sound only, then I would suggest one of two slip on options: the Rush Big Louie with 3" baffles or the Screamin Eagle Street Cannons. Both have a nice, deep rumble. The Rush is much louder, and I found them a bit much on longer runs.
Your best bet is to go to a bike night and listen to what you like and don't like. Take your time. Even some full exhaust systems are relatively quiet, so do your homework.
I thought I might need to gut the cat from all I'd been reading but at least on my ride the heat isn't severe enough to bother with it and the muffler is tuned to give me both the volume and backpressure ( low end torque,) that I desired. So yes, a slip on works just fine for me.
Cheap = cheap.
I'm jealous of the "classic" sounding bikes, and maybe one day I'll add slip on mufflers and a tuner. For now, 7,500 miles in, I'm really enjoying listening to the wind and the music without my ears ringing.
