Stereo headphone solution for 2014 FLHTK
FM mic to transmit my voice back to Boom!. The audio signal to the headphones is 100% stereo all of the time.
The Bluetooth transmitter (headphones) and the FM receiver (mic) are both inside the glove box (plus my 32gb USB stick). They are connected via audio extension cables which run from the glove box along the backbone under the gas tank to the area under the seat where they connect to the gas tank console's 7 pin connector via an adapter. I set all audio routing to the Headphones and then paired the Bluetooth transmitter with my Bluetooth headphones. The Boom! operates as though I am running a wired setup. My lapel mic is wired to the FM transmitter which I have in my jacket pocket so it is not 100% wireless but I do not need to unclip anything before dismounting my bike. For the most part I do not bother wearing the mic.
You can do this for as little as $100 not including Bluetooth headphones which would add another $50 plus depending on what brand you go with. I use Backbeat 903+ headphones which are still available on eBay. Your Bluetooth headphones only need to support the A2DP protocol which they all do. This solution does not need a specific brand for any component, nor does it require any modifications via Digi Tech.
My main objective was to listen to stereo music and get Navi prompts via my Bluetooth headphones. I have my Samsung S5 phone connected to Boom! via Bluetooth so I can listen to music from either the phone, the USB stick or the Boom! radio.
I went with the FM mic to replicate all the wired voice functionality. The volume level to my headphones is controlled by the left-hand joystick. I can quickly remove the BT transmitter, FM receiver and USB stick from the glove box if I so desire.
I have not taken phone calls or tested voice functionality at highway speeds but I will endeavour to do so and post my findings back to this thread.
Last edited by john31224; Jul 1, 2015 at 12:16 PM. Reason: Will update after further testing
Something like this
powered by this
Connected to this
Then there's the Sierra electronics device if ordering from overseas isn't your thing
https://www.hdforums.com/forum/new-r...h-ake-hc2.html
As far as my testing voice commands & phone calls at highway speeds go, the FM voice transmitter functioned perfectly but I did not find either mic compatible with my half helmet and the amount of wind I get. There was no extraneous noise sent but neither were practical for my setup. The mics tested were the inexpensive units which came with the FM transmitter/receiver and with different helmet/wind exposure someone else may find them adequate. Both of them certainly did the trick when stationary.
I am now going to buy and test a throat mic which I will again plug into my FM transmitter. I plan to get one in the $25 to $50 range, though one can spend less than $10 all the way up to $160 and probably more.
