Coolant level dropping...
Old Aug 3, 2015 | 03:23 PM
jpooch00's Avatar
jpooch00
Originally Posted by Vernal
And then there is always a Horror story:
https://www.hdforums.com/forum/new-r...015-ultra.html
Yeah, THAT'S the one that really got me to worrying, along with a few others that popped up in response to it!
Thanks,
JP
Old Aug 6, 2015 | 07:28 AM
jpooch00's Avatar
jpooch00
Default Update:
Well, my coolant level finally stabilized about 1/2" below the full line. It must have been air in the system, as others said.
Glad they were right!!
The sales guy at Sun is gonna give me a few ounces to top it up and that'll be that.
Thanks again to all the folks who posted on my thread.
Keep the rubber down,
JP
Old Aug 6, 2015 | 11:08 AM
mcouture's Avatar
mcouture
Mine did the same, 1/2" down after about 1,500 miles. I topped it off and it's not moved since....5,500 miles now.
Old Aug 6, 2015 | 11:15 AM
Bikerscum's Avatar
Bikerscum
Mine has 7500 on it now, it's dropped maybe 1/4". '15 Limited Low.
Old Aug 9, 2015 | 09:28 PM
Obsessed's Avatar
Obsessed
Stage III
I have a 15 limited. Doing the same thing. I can smell the coolant burning when I ride. Slight residue in pipe and ashy rear cyl spark plug. New cap, filler neck, and head gasket. Still slowly loosing coolant. Down 3/16" every 75 miles. Headed back to dealer.
Old Aug 10, 2015 | 07:10 AM
jpooch00's Avatar
jpooch00
No doubt the rear head that's leaking coolant into the combustion chamber of the cylinder.
Cheap head castings = porosity leaks and/or cracks. The MOCO would rather cheap-out on every part on these bikes and then waste huge amounts of money on warranty repairs than to just use quality parts to begin with.
It's always been that way with them for as far back as I can remember. They're incapable of learning from their mistakes!
Old Aug 10, 2015 | 09:59 AM
FLHTK2015's Avatar
FLHTK2015
Default Fears confirmed
2015 Ultra Limited, 1,500 miles. Bike has been to the dealer three times for coolant smell/ coolant loss without an external leak. They topped up a completely empty coolant tank twice (once @ 800mi, again @ 1,200mi) before I demanded a more thorough investigation. Air in the cooling system does not explain why I smell coolant when riding/starting the engine. During my first visit they refilled the reservoir to the proper level and advised me to monitor the level and continue riding as normal. The dealer kept my bike for a day on the second visit and did some riding- diag. They advised me that they completely filled the cooling system and purged system of all air and test rode for 20 miles. They pulled spark plugs and checked them, they appeared normal. They found no leaks and even did a pressure test of the cooling system and it all checked out. I got the bike back and rode about 150 miles before my reservoir was nearly empty AGAIN (all the while smelling coolant). Back to the dealer! During my third visit the dealer kept my bike again. The technician at the dealership was unable to successfully troubleshoot the problem, nor were they able to duplicate my concerns (smell/ antifreeze loss). The dealership ended up calling Harley Tech. I got a call a few days later stating that Harley believes there to be a leak in a gasket within the cylinder head or a leaking cylinder head so they have authorized the replacement of the front cylinder head. I am now waiting on the repairs to be done on my bike. The bike has been at the dealer since Aug 2nd. Luckily they were kind enough to provide me with a loaner bike.
Old Aug 11, 2015 | 07:20 AM
jpooch00's Avatar
jpooch00
If your state has a lemon law that covers bikes and they don't fix it this time, then you might think about making them buy it back.
If the MOCO has to buy back enough of these bikes, then there's a miniscule possibility that they'll fix the underlying problem with their cheap head castings - but I doubt it.
They would rather waste massive amounts of money on band aid fixes than to ever admit they screwed up in the first place!
What I really don't get is the part about a failed gasket. The coolant passage is completely imbedded in the head, so why did they apparently design-in a passage that needs a gasket (that can leak) in the first place?
Oh well... More inexplicable design flaws brought to you by the Almighty, All Knowing MOCO, I guess.
Old Sep 29, 2015 | 09:09 PM
Obsessed's Avatar
Obsessed
Stage III
Default Update to coolant loss.
After returning to dealer with same problem for the fourth time, H.D. Finally decided to send a new head for the rear cylinder. Picked up bike a week and a half later. Put 250 miles on it and the problem was worse. Brought it back and was looking into the lemon laws and how to deal with this situation. Got a call three days later from the dealer informing me that a new engine just arrived in a crate for my bike. Imagine my surprise. Even the MOCO gave up and gave in on this one. 500 miles so far and no issues. Good luck to those of you dealing with this issue.
Old Sep 30, 2015 | 08:01 AM
jpooch00's Avatar
jpooch00
I've been curious for some time as to whether or not the MOCO supplies a new engine with the same serial number as the original, since I've seen numerous posts of them replacing entire engines for one "un-fixable" problem or other.
It's a small thing, but I wouldn't buy a used bike unless the numbers "matched".
