Limited -- cb ptt switch -- rant!!
Old Sep 22, 2015 | 09:10 PM
p51bombay's Avatar
p51bombay
Originally Posted by Casper
1. Switch location is pitiful, someone has lost their mind! Move it to the left side where the mileage reset button....
2. No hand mic, what the !!!....get with it HD
3. I just bought a 2016 SGS and HD says I can't install a CB radio....WTH
Have a search - its been done.
Old Sep 23, 2015 | 06:27 AM
jpooch00's Avatar
jpooch00
Originally Posted by Scarz
I made this complaint almost 2 years ago with a recommendation that a button like the mileage button be placed on the right side. AND ALAS, nothing has happened. They claim that the Rushmore was designed with input from riders, but apparently their riders didn't use CBs.
The Rushmores were designed exclusively from the input of the MOCO's bean-counters and lawyers - and nobody else!
Old Sep 23, 2015 | 10:03 AM
eqcons's Avatar
eqcons
Originally Posted by woodmnctry
Having now completed several thousand miles on the limited I feel qualified to provide an evaluation of the position of the Push To Talk (PTT) switch for the CB radio --- in short and specific terms – “IT SUCKS A BIG ONE!!!’--- whomever at Mother HD that came up with this RH position has never ever ridden this bike and to used the CB --- why would anyone in their right mind try to put this on the same side as the throttle ??---it might work when a rider is on cruise control but trying to thumb the PTT while properly controlling the throttle is dangerous as hell especially in city traffic when trying to lead a group of riders. The pre 14 bikes with the switch on the LH side are vastly better plain and simple------sometimes one has to wonder about the experience and mentality of those engineering designer types that make these decisions --- get a rope!
Hopefully somebody will develop a means by which to move the PTT to the left handlebar position where it belongs --- as somebody previously mentioned it would be even better located where the odometer button is.
Yup, it's crazy. Been complaining about it since day 1.
Old Sep 23, 2015 | 05:21 PM
woodmnctry's Avatar
woodmnctry
So the next question is how hard would it be to reverse the switches -- cruise to PTT and PTT to the existing cruise position??---------has anybody done this ?? ------thoughts??----------
Not sure how many wires etc ?
Old Sep 23, 2015 | 06:44 PM
p51bombay's Avatar
p51bombay
With the canbus system I would say pretty near impossible. That said, for HD to make the change via software would be pretty easy. Don't hold your breath for it to happen until the revamp the touring bikes again around 2019.
Old Sep 23, 2015 | 06:55 PM
lp's Avatar
lp
I've been wanting to try this. Just have not been brave enough to take the switch assemblies apart.
Since each CAN BUS device (switch) has an unique address programmed into it, it shouldn't matter where the device is placed on the BUS.
Just got to be brave enough to move one and try it out. I would experiment on some take offs...
Someone will do it eventually.
EDIT: I just took one apart. The breadboard switches (just like the pressure switches under the keys on a computer keyboard) are fused and molded into the switch assembly. Not coming out. Not simple modules to swap. I put it back together and hope for a software fix. It does look like the physical switch buttons would be easy to swap as they are replaceable, but no way you're going to get the pressure switches relocated without destroying something.
Too bad.
Old Sep 24, 2015 | 02:06 AM
Bluehighways's Avatar
Bluehighways
Yea, Harley will have to reprogram the ECM at a minimum. On top of that the ECM is almost certainly using nonvolatile programming for their Body Modules. Hence a replacement ECM and not just a Software patch will almost certainly be required. Not a real likely expenditure of resources on Harley's part I'd imagine. But if I could, I sure would!
Old Sep 24, 2015 | 03:59 AM
eqcons's Avatar
eqcons
Can't be done - as P51Bombay says because it's Canbus. (Although again as he says, it would be an easy software change for the MoCo)
Old Sep 24, 2015 | 04:00 AM
eqcons's Avatar
eqcons
Too bad.
Yep, I tried that a year back.
Old Sep 24, 2015 | 06:06 AM
lp's Avatar
lp
I mean, it could be done, but it's going to be one of those deals comparable to changing out the LEDs in the instrument gauges. Tricky and no room for error.
Going to take patience, a steady hand, and good equipment to de-solder the controller from the board and relocate it.
We have a micro-miniature (2M) station at work I would try, but not on my brand new bike. If a spare set fell in my lap I would try.
It's not that it's CAN BUS that makes this hard - actually that would make it easier - it's that the back of the switches are molded in with some type of automotive silicone stuff so you can't even get to the contacts. Stinks...
