For those of you that have changed your Rushmore Bike Primary to the Narrow Cover, here is my question.
Is that all you need to do the switch the Cover and gasket or is there something like clutch pack that you have to change.
Thanks
Santa
I believe you have to change the derby cover as well.
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
HD says you do but now that I have one in hand I'm not so sure you MUST - I think there is a bit of a difference in that the narrow version is shallower but a cursory inspection (holding the narrow up to the std on the bike) suggests the hole pattern may be the same. Going to make the change probably Monday or Tuesday so plan to see if they will interchange or not at that time.
