Anyone using FOBO?
Old Nov 12, 2015 | 02:03 PM
buzdean's Avatar
buzdean
Originally Posted by RogFel
I have had mine on for a couple thousand miles now and I love them. I left the lock nuts off as I can't imagine someone stealing them.
I can't imagine anyone even noticing that they are on the bike!!
Old Nov 12, 2015 | 02:24 PM
bill_1202's Avatar
bill_1202
Originally Posted by amberwhiskey7250
I used the FOBO on my bike and ended up having to replace my rear valve stem. Not sure if it was related. The dealer said it was deformed and replaced under factory warranty. I am afraid of putting them back on now. They worked great when they were on the bike. Adding air isn't a problem. They just have a jam nut holding them on. I am also interested if anyone else has had issues with valve stems after installing these.
Looks like FOBO sells a cool set of chrome stems for these as well. Makes them easier to air up. Opps, I should have read all of the posts first...
Old Nov 12, 2015 | 08:27 PM
68 XLCH's Avatar
68 XLCH
Thanks for the information on pressure increases after a ride.
Nice to be able to monitor it at any time.
Old Nov 12, 2015 | 09:02 PM
cmtaylor's Avatar
cmtaylor
Thumbs up
My pleasure sir... In respect to balance issues I can't contribute as I run the "Balance Beads" in mine that would of course compensate for any balance issues... I can't imagine them making that much of a difference though...
Old Nov 12, 2015 | 09:08 PM
02BlueDeuce's Avatar
02BlueDeuce
T-valve optional accessory available in our web store for purchase. Suitable for rim valve hole of diameter 11.3mm or 8.3mm. This requires installation at a tire shop. Refer to Specification section for fitting details.
Which diameter do we need for a 14 SGS rear rim?
Old Nov 13, 2015 | 01:12 AM
big papa AZ's Avatar
big papa AZ
On the way to work tonight, my phone start vibrating in my pocket. The rear tire had gone out of range (high). So I guess it works!
In other news, I see they are making a smart watch app.
Old Nov 13, 2015 | 10:26 AM
buzdean's Avatar
buzdean
waiting for that answer to order a pair since the bike is at the shop for tire change(and winter storage)
thanks
Old Nov 13, 2015 | 12:06 PM
hbsoldier3's Avatar
hbsoldier3
I just ordered a set from Amazon. I will have them tomorrow the 14th.
Old Nov 13, 2015 | 07:18 PM
cptdenny's Avatar
cptdenny
11.3 mm is the answer.
I just installed the FOBO earlier. I haven't taken it for a ride yet, plan to do that later this evening. Stems got here as well and will install them at next tire change.
I didn't have the option of which tire stems to choose so I emailed the company and was told the ones they sent will fit my 2015 Road Glide CVO. I don't know if this size are automatically sent to US customers.
Old Nov 14, 2015 | 02:33 AM
big papa AZ
One PIA is anytime you make a setting change, like open pressure threshold, you have to remove and reinstall them. So far that's my only complaint.
