Anyone using FOBO?
I noted that the back tire heated up to 104° 50 psi, yet the front tire went no higher than 82° 47 psi after my 30 mile midnight ride.
Checking them now in my garage, front is 43.6 psi 79°, rear 44.2 psi 81°
I run niotrogen I have for a long time IMO when traveling i don't worry about temp or altitude.
i'm still on the fence on FOBO... how accurate are they and for how long compared to a good gauge? with nitrogen temp and altitude effect are minimal...
There's nothing to be on the fence about, dollar for dollar it's the best air pressure monitoring system presently available.
Comparing to a good gauge or a great gauge, it's better than a good gauge & possibly a great gauge since you can monitor your tires air pressures in real time on the go, or from up to 32' feet away.
How accurate is it all depends on which gauge you choose to compare it to.
Your good gauge won't alarm you of a air leak while riding, the FOBO does.
BTW regular air is comprised of nitrogen, in case you didn't know.
You have to decide if you want to use your good gauge checking the rear tire while on a tour, on your knees in a pouring rain first thing in the morning. What's that worth to you, what's your time worth to you checking your tire pressures before every or during every ride?
A hundred bucks is cheap insurance and may actually allow you to get more serviceability out of your tires.
In the end it's up to you to decide if all this peace of mind is worth it to you.
FOBO Bike sensors will not fit Harley Davidson motorcycles with side mounted valve stems or dual rotors. They will work on front wheels with single rotor only. Clearance must be checked before riding.
WTH? My Limited has dual front rotors.
Also on amazon.com...
Thanx,
Paul
