Cluth
Old Nov 6, 2015 | 08:14 PM
JakeUSAF's Avatar
JakeUSAF
Default Cluth
13K on my limited and I changed the Primary oil this weekend.It had redline oil in it. And it smelled so burnt it was not funny. Bike is still under factory warranty. Does not feel like it is slipping. Should I take it in and let the dealer check it out?
Shaun
Old Nov 6, 2015 | 10:26 PM
Gwaxley's Avatar
Gwaxley
Shaun
I'm guessing the redline had been it for 8000miles or 3000? What did you put back in? What was the color? How much metal was in the oil? Why would you want to bring it to the dealer?
At that mileage the oil should start looking better, most all the metal should be about done and the oil should start looking better. The smell will be diferant with diferant oils, I would run some formula + a few thousand and change it again. Catch the oil in a large clean container and see what comes out that's all the dealer is going to want to do if you don't any issues. Just because you think the oil smells funny is no reason to think there's an issue!
Old Nov 7, 2015 | 08:08 AM
THE PEG's Avatar
THE PEG
Had the same thing happen with my 06 RKC. Changed to Formula +. Everything has been good.
Old Nov 7, 2015 | 08:44 AM
JakeUSAF's Avatar
JakeUSAF
thanks for the input.
Old Nov 7, 2015 | 08:55 AM
smitty901's Avatar
smitty901
The primary is a wet clutch anything you put in there is going to change color and have some smell.
I do agree F+ is as good as anything in there. At least those of us that use it don't seem to have Compensators going out twice a year.
Old Nov 7, 2015 | 09:20 AM
db252's Avatar
db252
A very bad smelling primary oil is also a sign of your stator going bad. Check your voltage output.
Old Nov 7, 2015 | 01:11 PM
bikerlaw's Avatar
bikerlaw
Yeah, that's exactly what I was thinking. Are you maxing the stator output with accessories, extra lights, heated gear???
Old Nov 7, 2015 | 02:41 PM
nytryder's Avatar
nytryder
Old Nov 7, 2015 | 06:54 PM
Gwaxley's Avatar
Gwaxley
Originally Posted by nytryder
Yelp paying attention got it, stator over heating causing burnt oil smell, makes sense, did not know that but do now!
Old Nov 7, 2015 | 07:09 PM
mikeman54's Avatar
mikeman54
Shaun
Same issue on my 14 smelled bad at 15,000K 20,000K it wasn't noticeable and just did the 25K and no change,I was concerned about that smell but it hasn't created a issue yet and I do have a amp installed and volts are good
JTBarrett
Milwaukee Eight (M8)
116
Jul 22, 2019 07:16 PM
cali_heff
Nov 27, 2012 11:20 AM
XKnight
The General Motorcycle Forum
79
Sep 21, 2012 10:23 AM
WRAITH
Mar 30, 2007 11:29 PM
Kess
Oil Archive (no new posts)
Jul 20, 2005 12:25 AM
