Front brake vibration with new polished rotors
Old Dec 25, 2015 | 12:38 PM
wethead103's Avatar
wethead103
Default Front brake vibration with new polished rotors
Merry Christmas everyone!...just installed a chrome front end w/polished rotors on my 14 Ultra Limited. Everytime I apply the front brakes, I get a bad vibration. Will this go away after the polished part of the rotors wears off, or do I need to replace the brake pads. Thanks for any advise. Hope everyone had a nice holiday!!
Old Dec 25, 2015 | 02:03 PM
qtrracer's Avatar
qtrracer
The guy that polished them may have ruined them. I don't think new pads will help anything. You can try to make sure the rotors are bolted on the wheels totally flat, that the rotors are not bent in any way and are totally clean. Clean and deglaze the pads. If all this is OK then the rotors are have been ruined and will need to be replaced.
Old Dec 26, 2015 | 03:18 AM
CSMHOG's Avatar
CSMHOG
Have you checked for runout or warpage??
Attached Thumbnails Front brake vibration with new polished rotors-brg-6450.jpg
Old Dec 26, 2015 | 04:40 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It's the finish. Not the pads. And it may just never go away. I had a chilled spot on a cast rotor on my CR-V. Shuddered like crazy. You could rough the rotor and it would go away but kept coming back. Could not even fill it with your finger on the rotor but you could see a dull patch shaped like your palm.
Take some 120 emory cloth and hit the pad area with just the wheel spinning since look is important to you. Who ever polished could have polished it enough to affect thickness tolerance or maybe even runout as mentioned above. Standard blanchard ground rotors are parallel but the swirl finish from the grinding wheel is way to rough to be able to hand polish and keep things correct if that was what was done.
Old Dec 26, 2015 | 06:40 AM
CSMHOG's Avatar
CSMHOG
One more thing, did you install your bearings?? If so, did you install the primary side first?? If your wheel is single sided disc, the primary side is the brake rotor side ... if your wheel is dual rotor, the primary side is the left. This is important because this determines the exact placement of the rotors in the calipers. If you installed the bearings wrong, take them out, throw them away, and buy a new set. They're a one time install and then throw away. Yes you can probably get them out and back in again without noticing any damage but chances are you'll have premature bearing failure later.
Old Dec 26, 2015 | 07:05 AM
lp's Avatar
lp
Make sure that all 5 of the hub threads were cleaned out and the rotor bolts were installed at the proper torque level.
Make sure you push both pistons all the way back into the calipers to ensure you have no stuck pistons. (Reset basically).
Make sure you bed the new rotors.
Old Dec 26, 2015 | 09:09 AM
wethead103's Avatar
wethead103
Thanks guys for all the good advise. I will start with the Emory cloth and go from there. I did install a new front tire and wheel bearings when I installed my chrome dog legs and cowbells. I will recheck everything I did along with checking rotors for run out.
Thanks guys for the advice. "Happy New Year"
SG-Jay
Jun 13, 2016 10:09 AM
mikebaby
Mar 10, 2012 01:19 AM
dchoran
Jan 12, 2011 05:22 PM
Figstr
Oct 30, 2009 02:37 PM
jd_underdog
Jan 14, 2008 09:07 PM
