Making calls through Boom audio
Old Feb 26, 2016 | 03:15 PM
dspencer's Avatar
dspencer
Default Making calls through Boom audio
This may be covered somewhere in the manual and I just missed it. I was riding today and made a call though they system. Admittedly, I don't do that very often. That all worked well but my music came back and it seemed to freeze up. I had to go thru the prompts to finally get it working again. Is there something I need to do after the call stops. I was listening to Spotify through my iPhone and it was hooked up to the USB port. It was weird. Thanks for any input.
Old Feb 26, 2016 | 03:42 PM
bettingpython's Avatar
bettingpython
I haven't used a streaming provider for music on my phone so I don't know if that was the issue. So far with my phone iPhone 6 hooked up via USB port or a media stick in the USB port I haven't had an issue with the music not resuming after a call. I do have issues with the stereo freezing up and not wanting to work again until after the bike has been shutdown when using a thumb drive, so far haven't had that issue with my phone being used as a source though.
FYI if you haven't tried it yet don't bother blue tooth streaming your music. sounds like *****. But it does in my truck as well so I always plug the USB in.
Old Feb 26, 2016 | 03:56 PM
Dsm Limited's Avatar
Dsm Limited
I have used my phone with USB music playing and Pandora streaming while using the phone. While using USB for music, after a phone call the USB continues. While streaming Pandora after the phone call, Pandora will go into pause and I have to manually hit play on the phone to get it to resume.
Old Feb 26, 2016 | 04:06 PM
dspencer's Avatar
dspencer
Yes- I noticed that. I actually have Spotify offline so it's playing the music that was downloaded. Prob is I have it in the storage area with that little door hooked up to the USB. It's hard to pull that thing out and have it resume while riding
Old Feb 26, 2016 | 04:13 PM
cycle7447's Avatar
cycle7447
Community Influencer
dspencer- I have not experienced the situation you mentioned - however, perhaps you will consider this.
Transfer all of your music to a flash drive - it will play forever. Then, simply Bluetooth your phone and if a call comes in, all will work just fine
Hardcorerider45
2014-2024 Touring Models
Jun 19, 2017 04:57 PM
30glock
Apr 11, 2017 06:50 PM
TexasMotorcycleRider
Apr 29, 2015 08:29 AM
twitchcvma
13
Aug 11, 2014 09:04 AM
chinesepizzaman
11
May 27, 2014 07:25 AM
