Another Daymaker Bitc*
If you want to do replacement bulbs these are what you want:
http://www.fuelmotousa.com/i-2112160...CUSTOM%20FLTRX
Or you can try one of the others like Sirius or Trucklite. I am fairly certain Sirius makes the HD Daymaker. I would go with the reflector headlight over the projector.
No worries man.
This is the HD Projector LED bulb
This is the reflector model:
http://www.harley-davidson.com/store...r-led-headlamp
Some folks don't like the way the projector style clips the light on the sides. The reflector style is more like a regular headlight and projects the light a lot better. With the Fuel Moto bulb, you keep your stock bucket and reflector assembly and simply replace the bulb. The Daymakers are $400-600, while the bulb is only $50.
Your headlight is basically just a reflector with a halogen bulb. The reflector LEDs have multiple bulbs spread across the reflector.
Your headlight is basically just a reflector with a halogen bulb. The reflector LEDs have multiple bulbs spread across the reflector.[/QUOTE]
So, what I have read over the past couple of days is that depending upon the LED solution there may, or may not be a problem with daylight visibility, like from adjacent lanes or cross traffic. My question is if that is still the case with replacement LED bulbs installed in the stock halogen headlight assembly. And does it depend on the type or manufacturer of LED replacement bulb......
Sorry for the long note.
When I first got my RGS I was in the habit of running the Hi-Beams in the day time, but quickly had to change that. The guys I rode with, said they were too bright behind them and couldn't see anything behind me.
So, with the reflector style or replacement bulb I would say it is not as much of an issue because the light is being reflected in more directions than with the original projector style LED headlight.
Does anyone have a Reflector headlight that I could borrow for a few days to try it out, to see if it will light up the corners? I'd either send it back to you if it doesn't fix the problem or buy it outright if it does.
Also, as a side note, I added CD Rings LED blinkers on my bike because I had several friends tell me that my Projector headlight cannot be seen during the day, unless at exactly the perfect angle - it essentially looks like I'm running without my headlight on. The CD Rings don't throw much light but they did make a huge difference in daytime visibility.
Check out the Cirius or Trucklite reflector style headlights. Much cheaper than the HD model and I am pretty certain Cirius makes the HD one.
The CD rings do help in the fog though.
