Twin Cooled models 2017
Old Aug 25, 2016 | 03:38 PM
Brewmany's Avatar
Brewmany
Originally Posted by flyingace
When I bought my first Harley, it was 2006. Liquid cooling was INEVITABLE that year. (cause of the EPA)
Been hearing it every year since.
Harley will liquid cool what it wants. It just dropped an all new air cooled motor. That would not have happened if they HAD to go liquid cooled.
Yep. Spot on. They are apparently meeting current EPA with the Electra Glide Classic, Road King, and other non Twin Cooled bikes with the 107.
Harley has stated numerous times that the reason they went with the twin cooling for the Rushmore bikes was for rider comfort, not to comply with EPA. The whole point of Rushmore was customer facing.
Old Aug 25, 2016 | 04:27 PM
Uncle Paul's Avatar
Uncle Paul
Nice to have a choice. The water cooled have side radiators that fan vent the hot air to the sides of the bike, and away from the rider. You have the look and protection of lower fairings.
New oil cooled have a larger chin mounted radiator, also with fan cooling controlled by a thermostat. Gets rid of the engine heat with oil lines down to the radiator, and vents out the bottom of the bike. Have the cleaner look of no lowers.
Buyers choice...cool beans.
Old Aug 25, 2016 | 07:25 PM
dukdog's Avatar
dukdog
The 2017 Ultra that I looked at today had both the wet heads and the oil cooler. Maybe that would act like air conditioning in the Texas summer heat.
Old Aug 25, 2016 | 09:44 PM
Sailrider 1's Avatar
Sailrider 1
Im really quite surprised to see that the liquid cooling didn't get expanded to all the touring bikes. Kinda figured that was inevitable. Guess we know now that air cooling is gonna be around for a while still.
They did. All 2017 touring bikes are now liquid cooled or oil cooled. The oil cooled bikes have a large oil cooler on the front. Twice the size of the old oil cooler. The oil circulates around the head and valves for cooling. So in essence all 2017 touring bikes are now liquid cooled either by oil or antifreeze.
Old Aug 25, 2016 | 10:26 PM
tdkkart's Avatar
tdkkart
From my understanding based on a couple tech papers I've seen, the heads are the same between oil and water cooled, oil is run through the water jackets at the same pressure as water.
Old Aug 26, 2016 | 08:20 PM
Lu's Avatar
Lu
Also note that you can upgrade your oil cooler to a fan assisted oil cooler offered by MoCo
http://www.harley-davidson.com/store...oil-cooler-kit
Old Aug 26, 2016 | 08:43 PM
RollaMo's Avatar
RollaMo
Are you sure?
The "Twin Cooled" engines have a water pump in the same location where the oil cooler would be located.
The new oil cooler in the parts catalog for the '17's list as not fitting the twin cooled engines.
Fits '17-later oil cooled FLHR, FLHRC, FLHTCU, FLHX, FLHXS, FLTRX and FLTRXS models. Does not fit models equipped with Twin Cooled engines.
Twin Cooled
This one has a chrome cover over it, but that is a water pump and not oil cooler.
Old Aug 26, 2016 | 08:50 PM
Lu's Avatar
Lu
Originally Posted by RollaMo
Are you sure?
Twin Cooled
Correct. Perhaps he saw the voltage regulator and mistook it for an oil cooler.
- oil cooled M8 (models without lowers and Ultra Classic) have an oil cooler (voltage regulator is above it)
- water cooled M8 (models with lowers that have vents) have the water pump (voltage regulator is above it)
Old Aug 26, 2016 | 10:12 PM
texaswiz's Avatar
texaswiz
Originally Posted by tdkkart
The way I understand the tech documents I've seen, the models that aren't water cooled, ARE oil cooled, right down to using the same coolant passages as the water cooled heads, fed by a higher capacity engine oil pump on the oil cooled models, and fed to an oil cooler and an extra capacity oil system.
So technically, they are liquid cooled.
I say whatever works. If they can get similar cooling, water or oil, to what my twin cooled 110" CVO has, it's a win for everyone.
I wasn't thrilled with the water cooling when it first came out, but now that I own one I wouldn't be without. My 110 runs cooler than even my old 88" Wide Glide did.
The new engine does have a new oil pump Georotor or whatever they call it and it also holds about 5 quarts of oil in the crankcase plus I counted 10 rows on the new oil coolers. So ya, that is quite a bit of extra capacity when it comes to oil and cooling.
Old Nov 7, 2016 | 10:44 AM
cardboard's Avatar
cardboard
And I got only one question.
How much did the 2016 model water cooled SE Ultra Limited drop the temp.
3.7*
Can you really tell a difference ?
