Oil leak?
Old Sep 18, 2016 | 01:40 PM
mpr3369's Avatar
mpr3369
Default Oil leak?
Anyone had oil seeping out of the head bolts by the spark plug? When I picked up the new bike everytime I stopped at a light or something I smelled burning oil. I kept looking for oil leaks on the ground and stuff but didn't see any. Well I was messing with the rear spark plug the other day I noticed oil around the 2 head bolts. It only has 930 miles so it'll be a warranty fix but what would cause this? Should I be worried about a head gasket issue or anything? Thanks for any input.
Mike
Old Sep 18, 2016 | 02:43 PM
whocares's Avatar
whocares
Assembly lube.no oil can leak from those bolts.
Old Sep 18, 2016 | 08:38 PM
piper59's Avatar
piper59
Soak it up the best you can,take it for a ride and recheck it.Probably just assembly lube like who cares said.You don't have it all together already do you?
Old Sep 18, 2016 | 08:50 PM
Casper's Avatar
Casper
Same on my 16 Tri Glide, told by dealer assembly lube. I'll keep an eye on it but it should burn off quickly...
Old Sep 19, 2016 | 04:26 AM
mpr3369's Avatar
mpr3369
No still apart. Waiting on powdercoat. But damn you would think assembly lube would be burnt off in 900+ miles. Once it's back together I'll take it out and check it again now that I know where it's coming from. Thanks for the help guys.
Old Sep 19, 2016 | 05:20 AM
PeteF's Avatar
PeteF
I had a what I call weepage in that area when I purchased my 2016 RGS in April. It was just noticeable more on the left side at the bottom. It was assembly lube and burned off after about 600 miles. If the dealer is doing your first service have them check the head bolt torque. No issues since.
Old Sep 19, 2016 | 07:01 AM
jpooch00's Avatar
jpooch00
I've noticed a tiny bit around the bolt heads on my '15 too. Cleaned it off and it didn't come back.
Panthers65
EVO
16
Oct 29, 2016 08:29 PM
dmorganroth
Nov 4, 2015 07:48 AM
KJB
Jun 6, 2014 06:52 AM
Boltz
Screamin Eagle CVO Models
Aug 25, 2009 08:05 PM
les63
May 23, 2009 09:05 PM
