Shutting down and restarting the bike isn't fixing this issue. I don't use my nav a lot but today I needed it and it failed me. It seems to think I'm about 60 miles east of where I actually am. Would pulling the main fuse reset it?
If the system is locked up which it will do occasionally, then pulling the master fuse will reset the system. When you turn the bike off the Boombox system does lose all power for 3 or 4 minutes. So wait these few minutes or pulling the main fuse has the same effect. Once In three years my system started to do some really strange stuff, in this case I had to do system resett via the software. If you do a search on this forum, you will find detailed instructions on how to do this. Of course any dealer can do it for you. It is about a 10 minute job once you get the directions.
Thanks. It's not locked up though, it's just really, really confused.
2. Press and hold power/mute button. Turn IGN Switch to ACC position.
3. Continue to press power/mute button for 2 seconds after the WARNING screen is displayed.
4. Release power/mute button and accept warning.
The service menu may display Diag Service not Available when a menu option is initially selected. This message will clear once the system has finished performing the power-on process.
Thanks guys. Last night I pulled the main fuse and it did not appear to fix it. About an hour later, I went back out to look for routes that I might need to cancel and it was finally showing me back on my own street. I have no idea why it finally fixed itself.
I'll save the reset procedure but I have a question. My bike has been flashed for my amp. Would a reset screw up that flash?
