Primary oil question
Old Oct 1, 2016 | 10:12 PM
bkgabby's Avatar
bkgabby
Yep, second quart was bought for the extra 6oz. of the same material. It's all done and ready for a ride.
Old Oct 2, 2016 | 07:17 AM
santajim's Avatar
santajim
Originally Posted by IUOE ROB
Manual says 38 oz. I'm using 38 oz., if I'm short I'm taking a drive to the dealer (or wherever) and getting another quart...
Spent my whole life as a mechanic and I totally agree with this if it calls for 38 oz that is what is going in.
Old Oct 2, 2016 | 07:23 AM
jpooch00's Avatar
jpooch00
Originally Posted by bkgabby
I was getting ready to perform a 3 hole fluid change and had a question. I thought I had some formula + left over from the last change but I don't. I only bought 1 qt this time around so my question is can I use the 32oz of formula + and use mobile 1 20w50 to top it off at the 38oz required?
I think I'd just buy enough Formula+ to do the job. So far, that's the best stuff I've tried in my primary for quiet and smooth ops.
Old Oct 2, 2016 | 08:10 AM
stevep48's Avatar
stevep48
First time I changed the primary I desided to measure how much was in a qt of Formula +...36 to 37 oz.
Just did my 20k and so far I have measured 37 oz from 3 diffrent Formula + qts.
I just added the difference from a qt of Syn3 I had left over....
Each time the level comes up to the clutch basket as per the service manual, bike level on bike jack.
Old Oct 2, 2016 | 08:24 AM
Two Lane Tramp's Avatar
Two Lane Tramp
Soo, if I run out of milk can I use water in my pancake batter. Who the f*** cares.
Old Oct 2, 2016 | 08:35 AM
smitty901's Avatar
smitty901
Originally Posted by qtrracer
The oz's mean nothing. Only the height does. Bottom of the clutch basket, right to bottom. Oh still on my original compensator, running 1 liter in the primary on my 2008.
The 2008 and 2016 are different. Narrow primary and HYD clutch. Many read it wrong but a 2016 with narrow primary is 34oz wet fill unlike our early models. With the HYD cultch looking into see clutch basket is not as easy. Also 2016 narrow primary bike needs to be straight up when you fill it or it will run out before at correct level. .
This has been the standard for a long time Red line bike straight up. However when you look in a HYD ,narrow primary things look different.
Concept is still the same.
Old Oct 2, 2016 | 05:35 PM
Bodacious MC's Avatar
Bodacious MC
So, a quart of Formula+ isn't a standard 32oz's = one quart?
I just changed my a couple of days ago and added another 6oz plus a full bottle of Formula+ to mathematically come up with the 38oz that the manual states to replenish.
I guess I'll have to pick-up another bottle and measure the fluid in it.
Maybe I'm just assuming that a bottle is a quart????? Help!
Old Oct 2, 2016 | 06:45 PM
bkgabby's Avatar
bkgabby
Yesterday 1 quart of formula + was exactly 32oz ...lol
Old Oct 3, 2016 | 11:17 AM
JMC22's Avatar
JMC22
I just did all 3 holes over the weekend - went by what the manual says - 38oz - buy an extra qt and you'll have what you need for 5 or so changes
Old Oct 3, 2016 | 03:38 PM
JCBGlide's Avatar
JCBGlide
I mixed in Valvoline 20-50 dino oil (rated for wet clutches) w/ Formula + = no issues.
