Tire cupping
http://www.dunlopmotorcycletires.com/care/faq/
How can I keep my tires from cupping?
Top
You may not be able to entirely avoid cupping. Tire cupping or irregular wear is a somewhat common occurrence on all vehicles. On a four-wheel vehicle, you are advised to rotate your tires periodically to even out wear. Unfortunately, you do not have this luxury with a motorcycle because front and rear tires, unlike those on most four-wheel vehicles, are not interchangeable.
However, there are steps that can be taken to minimize cupping and uneven wear on a motorcycle: Maintain your motorcycle and particularly your front and suspension. Avoid hard braking whenever possible. Braking causes the tire to grab and wear in one direction. When braking is applied to the front tire, the load transfer over-flexes the tire and increases the tendency for cupping and uneven wear. Maintain your tire pressures. Under inflation and overloading of motorcycle tires are significant causes of cupping and uneven wear, particularly in association with hard braking and/or trailer use.
Once a tire begins to show signs of uneven wear, even following these steps may not improve the condition.
Tire companies can, and are, helping to minimize cupping and uneven wear but you, the rider, must do your part. Following the aforementioned guidelines will help avoid uneven wear.
How much run-in should I give a new tire?
Top
When new tires are fitted, they should not be subjected to maximum power or hard cornering until a reasonable run-in distance of approximately 100 miles has been achieved.
This is necessary for a number of reasons. Replacements for worn tires with different patterns and construction will not react the same. Also, a new tire is stiffer than an old tire. The new tire has a rounder tread profile, different contact patch and “lean-over edge” than the worn profile of an old tire. The new tire will also not react the same in combination with its remaining tire.
Carrying out the required run-in will allow you to become accustomed to the “feel” of the new tires and tire combinations, so you are better able to achieve optimum road grip for use in high speed, high acceleration and handling situations.
Should I use nitrogen in my tires?
Top
Nitrogen is not widely available and provides the same rolling resistance as tires filled with air. Scientific tests on the effect of the use of nitrogen in tires and changes in tire physical properties are inconclusive. In testing, nitrogen tires lost 2/3 as much as air-filled tires, so the benefits are minimal. If you want to maintain the nitrogen, any refills will need to be with nitrogen, not air. That means maintaining your tires becomes less convenient and more costly. The most important tire maintenance function is ensuring correct tire inflation pressure, which is easier using air than nitrogen.
Same for every other H-D I've ever owned.
The tire warranty is a joke, unless you put a screw in it two blocks from the dealer!
