rear reflector removal?
Old Mar 25, 2017 | 03:04 PM
Jersey Drew's Avatar
Jersey Drew
Default rear reflector removal?
I am aware that the correct way to get this removed is to remove the light bar, but with my meat hands I cannot get to the bolts in the fender with the wheel on. Is there any other way to get that reflector off?
Old Mar 25, 2017 | 03:24 PM
sirrat007's Avatar
sirrat007
Jack the back of your bike up, pull the mufflers, Slightly loosen the top shock bolts, then remove (with a jack supporting the rear tire) the lower shock bolts. Slowly let the jack down. I would think that might give you enough clearance. imho
Good luck.......Mike
Old Mar 25, 2017 | 03:28 PM
Jersey Drew
i thought about that basically swing the wheel down a bit. i could do that, but i was hoping that there was a less intrusive way. if not that is the way i will do it.
Old Mar 25, 2017 | 05:24 PM
tpcowfish's Avatar
tpcowfish
Did you do a search, i thought i read something about this shortly back, Not for sure, but thought id let ya know , in case it comes up in a search
Old Mar 25, 2017 | 05:34 PM
Jersey Drew
the search feature isn't my friend on this site. i have rarely found what i am looking for using the search on here. i will try it though.
Old Mar 25, 2017 | 05:56 PM
Cygnusx51's Avatar
Cygnusx51
Use Google. Search for something and also put in "site:www.hdforums.com". It will give results from the forum only.
Try: tail light reflector removal site:www.hdforums.com
Adjust your search terms if you don't get enough info.
I was able to remove mine by getting my hand up there with a regular box end wrench but it wasn't the easiest due to the lack of room to work. Made it happen though so I could install a license plate frame as well as remove the reflector.
Old Mar 25, 2017 | 06:37 PM
gregski's Avatar
gregski
I found that if I used a frame jack and jacked it just far enough to take the weight off the shocks I could get my meathooks up there to remove the license plate frame and the reflector. Not without a few cuss words however.
Old Mar 25, 2017 | 06:51 PM
Jersey Drew
thanks!
i have the tools to get the bolts out, however i am worried about getting the bolts back in once i am done....
Old Mar 25, 2017 | 07:27 PM
Cygnusx51's Avatar
Cygnusx51
Another thought, there's gotta be a close neighbor kid or something that wouldn't mind sticking his hand up there to help out. Might spark his interest in bikes! Maybe a riding buddy's kid could help out as well? Get the girlfriend/wife to do it and offer to do the dishes or something in return haha.
Old Mar 25, 2017 | 07:49 PM
OldPhat's Avatar
OldPhat
Try a heat gun or a hair dryer, it's just glued no, maybe you could add a light there.
