bagger bolts?
Old Apr 3, 2017 | 03:29 PM
Jersey Drew's Avatar
Jersey Drew
Default bagger bolts?
was just looking at my bike and it seems like there isn't really a need to use bagger bolts anymore. the back of the stock "bolt" doesn't seem accessible with a screw driver anymore?
Old Apr 3, 2017 | 03:38 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
I would agree. I don't see the bags going anywhere.
HOWEVER, I see a bigger issue. Assume your bag is locked - what is stopping someone from removing the torx screws that hold the latch onto the inside of the bag? (circled in red in the below picture) These are easily removable with a ratchet, and your bag is no longer locked...
Old Apr 3, 2017 | 05:07 PM
GLW Mike's Avatar
GLW Mike
I put bolts on my Limited last year. It just didn't seem to me the stock twist off bolts were very strong. They probably were fine, but looking at those stock bolts, just had so many notches in them. I sometimes carry a lot of weight in them, so I bought bolts to be safe.
Old Apr 3, 2017 | 10:20 PM
rv7garage's Avatar
rv7garage
^ Same here, I like the increased sturdiness of the bolts.
Old Apr 4, 2017 | 05:04 AM
CdnArmyGuy's Avatar
CdnArmyGuy
I pit bolts on mine last year also. After one of the org ones broke. Alot more secure they dont move around now.
Old Apr 4, 2017 | 06:36 AM
timbo141's Avatar
timbo141
If you are worried about that you could fill the screw with JB Weld or something similar. Then if you need to get the latch off later just chip it out. (Bags would need to be off to do this)
Old Apr 4, 2017 | 07:10 AM
1HD1C's Avatar
1HD1C
go to ace hardware and spend $11.54 that's what it cost me to make up a set of
" bagger bolts " in stainless
Old Apr 4, 2017 | 09:28 AM
BrownSanta's Avatar
BrownSanta
cheaper to go to lowes than pay for that crap...also HD now make a ratcheting setup for around $35
Old Apr 4, 2017 | 04:35 PM
jpooch00's Avatar
jpooch00
I have bagger bolts. Personally, I put a drop of blue loctite on 'em after finding one fallen off in the bottom of the bag.
Old Apr 4, 2017 | 04:51 PM
INJEKTER's Avatar
INJEKTER
never found the stock pin on the bottom of the bag...... i think its operator error , and doesnt matter what you use.....
