Electric problem
Old Apr 10, 2017 | 03:46 PM
remmag's Avatar
remmag
Default Electric problem
Ok ,hopefully someone will help
This is a weird problem
2015 roadglide special,tour pak with light bar installed
I have had some intermittent issues with the the bike throwing multiple odd codes
Harley blamed the tourpak lights but I call bull sh××
I bought a corbin dual tour last year with heat
When I plugged it up the way the corbin instructions said the service engine light came on as soon as I fired the bike up
Spoke with service depth, not their problem cause it's a corbin
I ordered the harness from hd for power accessories and tried connecting the seat again this year and as soon as I fired it up service engine light came on,I will pull the codes and post this evening
Also , a few times when I go to start the bike the fuel pump will run but when I hit the switch on the right handle bar it will do nothing, I can wait a few and it will start normally
I think I have a bad connection somewhere but I can't seem to figure this out
Thanks for any help
Old Apr 10, 2017 | 04:04 PM
russ33541's Avatar
russ33541
Is this an add on tour Pak and light bar? And did you add like new bars.
Old Apr 10, 2017 | 04:38 PM
remmag's Avatar
remmag
I just pulled the codes
There is a bunch
Ecmu0001,u0140,u0142,u0156
​​​​​​Bcm,u0001
Speed ,u0121,u0140,u0100,u0184
Abs u0001,u0003
Radio u0002, u0140
Thanks
Old Apr 10, 2017 | 05:06 PM
remmag's Avatar
remmag
Yes it is an add on tour pak and light bars
I had ape hangers installed b4 I brought it home
Old Apr 10, 2017 | 08:03 PM
pswomack's Avatar
pswomack
There is a bunch
​​​​​​Bcm,u0001
Abs u0001,u0003
Radio u0002, u0140
Thanks
I'm starting to think the problem starts within the Corbin Heated Seat wiring, not likely that the LED lights in the Tour Pak light bar would pull the Can-Bus system down like that, unless something wasn't wired correctly. I'm thinking that somehow Corbin or the HD harness you bought is interfering with the Can-Bus Communication line either to or from the BCM, maybe overloading it somehow.
Here are the list of U Codes from the HD Manual.
U0001 CAN BUS error
U0002 CAN comm bus perf error
U0003 Network management monitoring
U0100 Lost comm w/ECM
U0121 Lost comm W/ABS
U0140 Lost comm W/BCM
U0141 Lost comm w/LHCM
U0142 Lost comm w/RHCM
U0156 Lost comm w/SPEEDO
U0158 Lost comm w/fuel gauge
U0159 Lost comm w/volt gauge
U0160 Lost comm w/ fuel and volt gauge
U0184 Lost comm w/radio
U0185 Lost comm w/Amp 1
U0186 Lost comm w/ AMP 2
U1302 ACC bus perf error
U1401 Lost com w/CB
Old Apr 11, 2017 | 07:11 AM
remmag's Avatar
remmag
I spoke with a dealer a town over and they agreed to look at it Saturday
I am pretty damn sure this has thrown all these codes b4 seat was purchased
I wonder ( dealer installed apes when new) if there could be an issue in the handle bar wiring causing codes
I really don't understand can bus system
Thank you
Old Apr 11, 2017 | 09:02 PM
Hammz's Avatar
Hammz
Thank you
I'd put money (but not a lot cuz what do I know?) on the handlebar installation being the root cause here.
Old Apr 12, 2017 | 06:18 AM
Steel Wheels's Avatar
Steel Wheels
A can bus system in autos typically toggles at around 2.5V. All modules are connected with two wires, a high and a low. Any wire that touches power or ground will crash the system. GM uses combs to provide central points that can be used to isolate different components and help diag intermittent - this is where I always started, depending on which DTC's were set.
Your TBW would likely be on that circuit, so I'd start by disconnecting it prior to the point where the wires go into the bars. Disconnecting both switch harnesses should reduce the number of DTC's to just those components.
Hope you find it. Good news is, it's probably NOT a module; wiring is the cause of 90% of this stuff. And a bike's a whole lot less complex than a car...
Gatlin
Mar 25, 2019 07:08 AM
Roadie13
Jan 27, 2018 07:27 PM
WB
Mar 26, 2015 08:22 PM
WB
Electrical/Lighting/Alarm
Mar 26, 2015 08:21 PM
pak
May 30, 2006 12:56 PM
