Poly Riser Bushings
Old Apr 16, 2017 | 02:03 PM
Hinzy's Avatar
Hinzy
Default Poly Riser Bushings
Any tips on installing these $#!!!ing bushings
can't seem to get both ends seated together along with the bushing that rides in between much stiffer than stock
TIA
Hinzy
Old Apr 16, 2017 | 03:55 PM
Cygnusx51's Avatar
Cygnusx51
Sometimes you have to trim the flat part of the bushings so that they will seat together. Otherwise you'll have issues torquing the riser bolts and keeping everything level and flush. There's not much forgiveness like with the rubber bushings where they squeeze together.
Lay some sandpaper on a flat surface so you don't create any angles and do a little at a time.
Old Apr 16, 2017 | 06:49 PM
Hinzy's Avatar
Hinzy
Well managed to make a Menards run bought some 3/4 longer bolts and some flat washers managed to draw the bushing into the frame that way,
biggest problem now is wiring the bars while attempting the left side heated grip barley went on the wild 1 578's did not even force the grip won't slide in the bar and to top it off
the heated grip control popped off can't get it back on
Had to walk away at a loss as to reassemble the grip............
Seems everything I touch lately turns to **** geeeez
Look like a trip to the dealer for new grips
Old Apr 17, 2017 | 08:10 AM
Magnut1's Avatar
Magnut1
Compressed mine with a C clamp. I posted a write up a few months ago.
Old Apr 17, 2017 | 12:28 PM
wparente's Avatar
wparente
I had to ream out my 578's to get the heated grip to work. There is a chance it might work with grease, but that's iffy too.
Old Apr 18, 2017 | 06:18 AM
Hinzy's Avatar
Hinzy
Bought a wheel cylinder hone yesterday and reamed out the bars.
The tight fit is rubber type insulator in the very end of the grip,not sure what its function is but that is the culprit.
Ordered a new left grip yesterday to hopefully complete the project by the weekend.
robbyville
Jan 29, 2015 01:56 PM
quan00
Dec 23, 2011 09:24 PM
shagnasty
Jul 13, 2010 07:03 PM
alwaysarider
Custom Models
Jun 25, 2008 12:06 PM
ronyd
Oct 9, 2007 08:42 AM
