Increasing CB Range
The "Shorty" antennas are not long enough to resonate at 27 MHz, hell about the only antennas that are, are the 108" whips.
Most of the antennas have a loading coil (usually at the bottom) the coil "fools" the radio and signal into seeing a longer antenna, so the majority of the signal travels down and leaves the antenna instead of flowing back towards the transmitter, too much signal flowing back is high VSWR.
Also, The lower the RF frequency, the longer antenna required.
Channel 1 is lower frequency then the other 39 channels, requiring a longer antenna.
A properly designed load would allow a paperclip to look like a good match. Not much signal would be radiated effectively, but the radio sees a good match.
The proper tune you speak of allows for using the shorty antenna not the other way around.
Ride Safe Everyone,
Yes, a lower frequency requires a longer antenna. And a 108" whip antenna will provide a good match (SWR) at CB's frequencies (26.965 Mhz for channel 1 to 27.405 Mhz for channel 40).
However, even a 108" whip antenna needs a good ground in order to properly radiate rf signals & w/o that ground won't present a good SWR. So a good place to start will be to ensure the bike's ground system is as good as it can be. Bonding the metal base plate inside the tour pack to the rear frame sub-assembly & then bonding that rear sub frame to the main frame will make a substantial improvement. This approach is what J&M offers with their Part # CBAU-HU14 CB antenna improvement option (although their included replacement coax stub does relatively nothing).
The shorty antenna is actually a spirally wound wire on a fiberglass mast within an outer jacket. Because of this it does resonate at 27 Mhz. If fact, the design is better defined as a "top load" antenna. The oem antenna has no "load" in its' design. I know this as fact because I have used an antenna analyzer to confirm resonant frequencies for both the oem & shorty. The longer oem antenna has a resonance of roughly 25.4 Mhz, while the shorty antenna is resonant at roughly 27.4 Mhz (channel 40 is 27.405 Mhz).
A couple generations back, H-D did use a loading coil in the CB antenna system, but the last 2 iterations of their antenna design has been done w/o any loading coil at all. They also included a 75 ohm Motorola slip fit connector as an inline connector that was located inside the tour pack, but in 2014 was moved outside the tour pack where it is exposed to moisture & subject to corrosion because that connector is not water tight. That's what happens when you put an "EE" idiot with zero knowledge of RF theory in charge of the redesign.
The "properly designed load" that allows a paperclip to look like a good match would most likely be mostly resistive and dissipate the rf signal as heat. But it would not be a properly designed antenna system. So you are correct, the ERP (effective radiated power) would be nil in this example.
Finally, to tie everything together, the junk coax running from the CB to the antenna on the tour pack (that includes the 75 ohm Motorola connector that corrodes when it gets wet) needs to be replaced with a single run of 108" (1/4 wavelength) high quality, well shielded 50 ohm coax.
So while your statements are generally correct in theory, in this case, other issues complicate things.
Most bikes now come with a general length antenna that will work satisfactorily but then that limits the range of output and reception.
I don't know if any bike shops carry an SWR meter, or call around to friends to see if they know of anyone that has one, but that should be the first thing to check.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
Also on amazon.com...
http://www.claysradioshop.com
http://fieldcomponents.com/ custom built 10 foot length with no connector on one end & a male TNC connector on the other end. The CB module is fitted with a female bulkhead TNC connector.
Go to their menu, select the coax builder option & put together your order. I used the standard RG58C/U coax that has a tinned copper center conductor & tinned copper shield, which is very adequate for this application & about 4 times better than the oem junk.
If you want the capability of removing the tour pack, order an 8 foot coax with male TNC & mini UHF female connectors, along with a 2 foot coax with mini UHF male on one end, no connector on the other end.
