Increasing CB Range
I would also make sure both of the grounds are connected with a good connection to the ground plate in your tour pack, that is what provides the ground plane for the antennas power to be transmitted.
Good luck
http://www.jmcorp.com/ProductDetail....ctID=CBAU-HU14
See this post:
http://https://www.hdforums.com/foru...l#post16254524
Good luck
When I got the Ultra Limited, I had the same problem with the CB. My squelch was pretty much useless. If I bumped it up two or three bars, it acted the like squelch was closed. So I did the same thing, and put the whips on this bike and again, it fixed it. I can now broadcast and hear for miles and I now have full range of the squelch.
Most of the other road captains that have the newer bikes have switched to these antennas as well and are pleased with the results.
The "Shorty" antennas are not long enough to resonate at 27 MHz, hell about the only antennas that are, are the 108" whips.
Most of the antennas have a loading coil (usually at the bottom) the coil "fools" the radio and signal into seeing a longer antenna, so the majority of the signal travels down and leaves the antenna instead of flowing back towards the transmitter, too much signal flowing back is high VSWR.
Also, The lower the RF frequency, the longer antenna required.
Channel 1 is lower frequency then the other 39 channels, requiring a longer antenna.
A properly designed load would allow a paperclip to look like a good match. Not much signal would be radiated effectively, but the radio sees a good match.
The proper tune you speak of allows for using the shorty antenna not the other way around.
Ride Safe Everyone,
The difference in range and audio quality between the stock Harley CB radios and everybody else was startling. Harleys were the worst, with the Goldwing guys having excellent range and clarity, and J&M in the middle. The Harley's range was so bad that the only way for the front and rear of the pack to communicate was by "passing it on", that is it had to be retransmitted over and over to multiple bikes to get from back to front or vice versa.
Overmodulated, distorted, and full of static. Sucked.
