changing wheels
Old Jun 13, 2017 | 08:34 PM
varider12$'s Avatar
varider12$
Default changing wheels
Ok so I have aquired a set of 2015 SG wheels with tires front has calipers rear no caliper or pulley. I have only had bike for 3 months and was inquiring how hard is it to swap wheels & rear rotor & pulley? Dealer wants $190.
Old Jun 13, 2017 | 08:58 PM
Taranwanderer's Avatar
Taranwanderer
Is that for front and rear? That sounds like a good deal.
Old Jun 13, 2017 | 09:34 PM
varider12$'s Avatar
varider12$
Yes they quoted me 1 hr @ $95 per axle. I am supplying all parts its just for the labor.
Old Jun 13, 2017 | 09:41 PM
GalvTexGuy's Avatar
GalvTexGuy
Do you have a lift? Do you have the tools you would need to properly remove and install the wheels? Do you have a service manual?
Old Jun 13, 2017 | 09:47 PM
varider12$'s Avatar
varider12$
I have a lift and manual not sure if I need any special tools. I have changed wheel out on my v rod many times and other bikes just never this new to me Ultra, for the service manual doesn't look to tough?
Old Jun 14, 2017 | 12:16 AM
GalvTexGuy's Avatar
GalvTexGuy
Well, there you go. You've answered your own question haven't you?
Old Jun 14, 2017 | 09:04 AM
varider12$'s Avatar
varider12$
Just trying to get a handle on the job at hand.
Old Jun 14, 2017 | 09:33 AM
nutsandbolts5212's Avatar
nutsandbolts5212
It's easy, just follow the manual and you'll be fine. Also, I believe you are going to need a 36mm wrench/socket for the rear.
Old Jun 14, 2017 | 10:17 AM
cycle7447's Avatar
cycle7447
Community Influencer
I am not good at changing those sort of things. So, if you are like me, I may just trust the dealer.
Old Jun 14, 2017 | 10:49 AM
GalvTexGuy's Avatar
GalvTexGuy
Along with a torque wrench and a belt tension gauge. Depending on mileage and condition of the bearings, he might consider changing those out while he's got the wheels off the bike, in which case he'll need a bearing removal/installer tool, along with new bearings.
