Transmission drain plug...
Old Jul 5, 2017 | 09:05 PM
Jethro's Avatar
Jethro
Thanks for all the responses. I removed all three plugs--tranny, primary, and oil, and again... ALL three NOT tight. I barely moved the socket, and basically after that all were what I would call hand tight. Ugh. Alll three, so I know it was done on purpose that way, and all three o rings chewed up and broken! Weird.
Old Jul 6, 2017 | 09:35 AM
grumble's Avatar
grumble
I just don't see this as weird.
The O-ring provides a seal - O-rings are designed as "one and done." I can't remember off-hand what the torque spec for the drain plugs is, but it's NOT tight and one can easily over-tighten by hand.
IIRC the threads are NPT and thus between the pipe-fitting and o-ring, it doesn't require much to hold it together.
Old Jul 6, 2017 | 02:36 PM
Sam2010's Avatar
Sam2010
Actually I don't think they put that stuff on the oil plugs for leaks. I think it's put on there originally because the threads are going into dry metal I think it's more like a lubricant type sealant. Once the bikes operational and has fluids in it the threads are always lubricated.
Old Jul 6, 2017 | 02:46 PM
IdahoHacker's Avatar
IdahoHacker
11105 o-rings are $3.99 per hundred on ebay.
Old Jul 6, 2017 | 03:13 PM
KrustyKush's Avatar
KrustyKush
Torque spec for my 2016 FLHTCU is 28.5 n-m for all three plugs. That is a lot more than "finger tight" for sure. I doubt finger tight would keep these plugs in their holes for long.
As for the o-rings, the manual sez replace at oil change "if necessary" (as I recall) and my experience is that, if the bolt is tight to 29 nm then the o-ring comes back out in 5k miles in perfect condition and can be re-used. I know because I have already reused a set without trouble.
I do take care to clean out the seating area and put a small daub of motor oil on the o-ring before installing.
Old Jul 6, 2017 | 06:59 PM
94 ultra's Avatar
94 ultra
Originally Posted by Vibeman
Similar situation to KrustyKush,
2016 FLTRU. I Allowed dealer to do 1k service, when I removed engine oil plug myself at 6k found plug not tight, white sealer on threads, o-ring chewed up. I complained to service manager, he apologized and gave me voucher for free oil change. I let them do it again at 11k (for free), when I removed plug myself at 16k.....same situation! So I drained oil, cleaned everything, put new o-ring on plug, light grease coat, no sealer then torqued to spec. I then removed the plug and the o-ring was chewed up!?! I am thinking perhaps the o-ring groove surfaces on the plug, the pan, or both might be out of spec. (they looked ok) Or maybe the dealer gave me the wrong size o-ring. I have had two other Harleys and never had this problem. In fact I have re-used drain plug o-rings multiple times with no damage. I have not had a single drop of oil leak out in any of the situations so maybe it is a non-issue. I just don't think sealer should be necessary in a properly torqued o-ring fitting. Especially when minimal pressure is present.
I had this happen to me also at 2000 miles for a oil change that I did after the Dealer did it at 1000
Plug was loose
o ring was tore up
I bought some 013 Vitriol Orings from Fastenal
they are supposed to be bulletproof
we shall see
Old Jul 7, 2017 | 04:20 AM
Bluehighways's Avatar
Bluehighways
Yea! And those are the expensive ones!
Also 28.5 nm is 21 lb/ft of torque, and I think the range is 14-21 lb/ft. So in real world terms that'd be snug but not tight! You're not trying to fasten two parts together that want to fly apart. You just want a good seal and snug enough that the plug won't fall out. Just beyond finger tight . . . probably works just fine.
Old Jul 7, 2017 | 05:45 AM
Vec's Avatar
Vec
Thumbs up
yep, thats where i bought my bulk bag of o-ringsas well.
Old Jul 7, 2017 | 05:53 AM
Notgrownup's Avatar
Notgrownup
I use white plumbers putty on all 3 plugs when changing my fluids. Double safe with a new. I-Ring each time.
Old Jul 7, 2017 | 06:08 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Thread sealant is a good thing. I always use it and have found that the HD dealer I go to uses it also.
What does bother me is everytime I remove a drain plug the o-ring is trash. I assume that the seat design is not the best or there has to be sharp edges.
But four bikes and well over 100k miles and no issues.
