Question about checking oil level
Old Jul 27, 2017 | 04:01 PM
matthew6279's Avatar
matthew6279
Default Question about checking oil level
Manual states that checking the oil cold the level should be mid way on the dip stick marking. I've checked it both hot a cold and either way the oil level is to the stop of the markings on the stick? I just had it in for an inspection at my HD dealer too.
Old Jul 27, 2017 | 04:03 PM
ElectraJim's Avatar
ElectraJim
Sounds like it's over filled. You should check your oil on the jiffy stand, cold, and the level should be about half way up the stick. If you're checking when it's hot on the jiffy stand, then the level should be all the way to the top mark.
Old Jul 27, 2017 | 04:04 PM
matthew6279
I've checked it both hot and cold on the stand. Seems like it's the same level either way. No change.
Old Jul 27, 2017 | 04:06 PM
matthew6279
Also I'm new to HD. When it's hot why is there more oil on the dipstick? Seems like if its hot it's been running so oil would be coating the engine components. When cold I would think the oil would be higher as it has drained down to the pan?
Old Jul 27, 2017 | 04:10 PM
matthew6279
It was supposedly just changed before I bought it. Think I might drain it and go back with straight 50w for a few months anyway. Make sure the level is correct.
Old Jul 27, 2017 | 05:12 PM
Kermie's Avatar
Kermie
Yeah check it on the Jiffy Stand. I don't believe there is any marks on it for being upright.
Old Jul 27, 2017 | 05:14 PM
Puttnik's Avatar
Puttnik
There is a mark for upright.
matthew6279
There are marks for both jiffy stand and upright. But as stated above I am checking in on the stand.
Old Jul 27, 2017 | 05:28 PM
Kermie's Avatar
Kermie
Ok, I must be missing something then
Old Jul 27, 2017 | 06:06 PM
matthew6279
This is out of the manual but it's what mine looks like.
