Boom problems
Old Aug 15, 2017 | 06:16 AM
GalvTexGuy's Avatar
GalvTexGuy
Originally Posted by flash1964
I'm using a PC windows 10. I've tried 2 different jump drive 1 was brand new. I unzipped both files to drives. I had done this before and never had problems. How can I get it to go back to normal screen? I had read that we were have trouble with it working with new update. Ive tried to reset with key off hold down power button then turn on and have pulled maxi fuse. Any other suggestions?
With the drive out turn on key after a few sec sez to insert drive to finish up date. I do that and I let it set for 3 hours and still it cycles between black screen and the please wait.
If I understand, you don't have a flash drive plugged in, and when you turn on the bike, it's asking you to insert the flash drive to finish the update?
When you pulled the fuse, did you wait at least ten minutes before plugging it back in?
Old Aug 15, 2017 | 06:21 AM
nyokie's Avatar
nyokie
maybe try the previous update version on your stick and insert that?
Old Aug 15, 2017 | 07:45 AM
flash1964's Avatar
flash1964
Thanks brothers problem resolved! To get out of loop I put USB drive with radio update on it and it started updating. Then I reverted to an older version, then installed the dealer update then installed the newest radio version. All is good now.
So lesson learned on this update DONOT update radio then Nav.
Thanks again!
Old Aug 15, 2017 | 08:10 AM
cycle7447's Avatar
cycle7447
Community Influencer
Glad to hear you got it worked out. Thanks for letting us know
Old Aug 15, 2017 | 09:27 AM
nyokie's Avatar
nyokie
Thanks again!
No problem same thing happened in my pickup and that was solution, lucky guess, glad it worked.
Old Aug 15, 2017 | 10:38 AM
rwven's Avatar
rwven
I had the same issues a few days ago trying to install the new dealer POIs. One I installed the previous version of the system update the POIs loaded with no issues, I then reinstalled the newest system update and everything seems to be working fine.
Old Aug 15, 2017 | 01:22 PM
Sierra977's Avatar
Sierra977
Sitting at dealer right now just got word from Harley Service center they have no solution to Boom locking up with POI update. Harley says radio has to be replaced. Local service tech asks me to try backdating BOOM software to see what happens.
Old Aug 15, 2017 | 01:33 PM
rwven's Avatar
rwven
I don't know if this has been stated already, and I don't want to read the entire thread to find out, but this is what worked for me in the end.
Tried to install POI update and system would try to load, go black and try to load again repeatedly. Unplugged thumbdrive and got screen saying to reinsert thumbdrive.
Inserted thumbdrive with latest update and allowed it to reinstall. Then installed previous update. The system would not directly install the previous update directly from the attempted POI update.
Successfully installed the POI update.
Reinstalled the latest system update.
This involved about two hour's worth of muttering and cussing before I finally got things in the correct order by trial and error......
Old Aug 15, 2017 | 01:49 PM
dswansbiker's Avatar
dswansbiker
One of these days I have to turn my Boom on to see if it is working
I still think I am riding a Road King I guess.
Old Aug 15, 2017 | 02:10 PM
Bodacious MC's Avatar
Bodacious MC
My two favorite things about the boom are the real time GPS Map, or when turned off, the Bar and Shield with Clock.
