Cupped tires
Old Sep 17, 2017 | 12:32 PM
steelerdude1's Avatar
steelerdude1
I just replaced my factory rear (12988 miles) due to bad cupping. Still had about 5/32 left. Checked with dealer on warranty, and they basically laughed at me. Said I set a record, as most don't last more than 8000 miles. (I called BS, but that's another story for another day)
I will tell you that you will not get anything warranty wise, if you do, I'll be surprised. - I ended up choosing an Avon for the replacement. - comes with both a 15K Milage warranty and a road hazard warranty. - must hold on to original receipt, and register it with in 10 days.
Old Sep 17, 2017 | 01:17 PM
dougyf's Avatar
dougyf
Unfortunately it's the nature of the beast for the rear tire on touring bikes to start cupping at approximately 4500 - 5000 miles.. Although it only started happening in 09 when Harley went to the wider Dunlop. The narrow rear tire on the pre 09 bikes never cupped. Back in 2010 I complained about this & Harley said it was normal wear. I then contacted Dunlop directly & they offered a replacement , but I had to pay for the install, which they should of covered. Anyone who says they don't hear the noise of a cupped tire probably has loud pipes .
Old Sep 17, 2017 | 08:40 PM
cycle7447's Avatar
cycle7447
Community Influencer
My 2011 - I was getting 20,000 front and rear. My 2014 - 1st set, I got 18,990 - front and rear - only changed them because I was headed for a 3000 trip.
My next set has about 13,000 miles on them. Front has 3/32 and rear has 5/32 - but I can see some cupping. Will wait until next season to put new ones on. In my opinion, no need to install new tires now (almost October) and have it sit in the garage until early May
Old Sep 18, 2017 | 09:42 AM
KrustyKush's Avatar
KrustyKush
Pretty normal, I'd say. All tires cup, or scallop (depending on what you call it) and it is much worse on motorcycles because you can't rotate to even it out. The American Elites last over 20k, but they get real noisy after 10k miles due to the cupping. Yes it will affect handling, but usually we adjust to it gradually as the tire wears. Then, when you get the new tires installed everything feels weird for a little while as you adjust to what new tires feel like, and it begins all over again.
Old Sep 18, 2017 | 03:56 PM
zoozoo's Avatar
zoozoo
I was getting 20,000 front and rear with my 2010 and I could have put another 2,000 but I change because I was going on a long trip. I never got more than 8,000 on the rear and 12,000 on the front of my 99 Glide.
Old Sep 19, 2017 | 06:28 PM
slapshot12's Avatar
slapshot12
On my '11 Ultra Classic, they cupped at 12k and my current '15 Limited they made it to 16k before I got tired of the humming and replaced the tires.
Old Sep 20, 2017 | 09:01 AM
jpooch00's Avatar
jpooch00
Really weird. I've got 10,000 miles on my '15 limited and the tires are still perfect. No cupping, no noises, no problems at all. I'd estimate at least 8 to 10 thousand more miles before having to think about replacement with another set of OEM's.
Guess I'm just lucky. I'm a pretty conservative rider, though, so that probably makes a difference. I run 38 PSI front and 42 in the rear, always solo with 20 PSI in the shocks, FWIW.
Old Sep 20, 2017 | 10:52 AM
720Deere's Avatar
720Deere
And there you have it! Up your payload to over 400 lbs and that is where the cupping really gets hard to prevent. Recommended maximum psi for the rear tire seems to not be enough for maximum payload. Mine made it to around 10,000 miles before I started to get the hum while leaning into a turn. At 13,000, the rear tire is cupped, but it is still getting the job done.
Old Sep 22, 2017 | 10:19 PM
flash1964's Avatar
flash1964
I have got reply from MoCo and said was 'normal wear" because of terrain where I live and ride. Contacted Dunlop and was told the same thing. I think this is a cop out just don't want to back there product. Prob will replace with commander 2 in the spring. Will limp along for short rides till then. Thanks for all the replys you guys are the best.
Old Sep 22, 2017 | 11:14 PM
lightweight bob's Avatar
lightweight bob
Default Tire cupping
I agree that it's most likely the tire. Been around the block a few times and had the problem with both Dunlop and Metzler.
The Michelin Commanders seem to do it the least for ME but may be different on your bike. Dunlops were the worst as they
were more out of round than others - just my experience.
