SG Handlebar Help
Old Sep 22, 2017 | 11:12 AM
torchmaster's Avatar
torchmaster
Originally Posted by pswomack
These are the bars that I went with, after 3 rotator cuff surgeries (2 on left, 1 on right shoulder) I have no more Shoulder/Back pain, these bars really made a BIG difference!
Khrome Werks Handlebar 1" 2+2 Nrw Fl part# 300519 Narrow sweeper bars 2in up plus 2in back. End Rise: 13.53in. Width: 31.77in. Center Width: 12in. Pullback: 7.64in.
I put these on my wife's 15 sg and they made a huge difference for her with slow turn maneuvers. She is only 5' 2".
Install was a breeze, biggest pita was right side wires through bars. You could just run them outside though then it would be super easy.
There's a good youtube video also.
Old Sep 22, 2017 | 11:15 AM
rott_lab's Avatar
rott_lab
Out of curiosity, why did you put the 2+2 on for your wife if she's only 5' 2"?
I'm debating between the 2+2, and the +2 only (2" back, but NOT 2" up). I'm 5'8" with a longer inseam (31-32"), and I wasn't sure if I would want to go "up" at all. Also, does the 2+2 require the use of handlebar mounted mirrors?
Thanks!
Old Sep 22, 2017 | 01:45 PM
torchmaster
Thanks!
I know but thats what she wanted sooo.
Yes the 2+2 require stem mount mirrors if you don't want to look at your hands
Order from dennis kirk and if you want to exchange / return them they only charge 5 bucks iirk.
Old Sep 22, 2017 | 02:01 PM
rott_lab's Avatar
rott_lab
Ok, great, thank you very much!
Old Sep 22, 2017 | 04:47 PM
pswomack's Avatar
pswomack
Thanks!
I'm 5'9" with a 32" inseam and I'm glad I went with the 2+2 bars, no shoulder/back pain, no numbing in my hands and it's much easier doing parking lot maneuvers.
Yes you would have to use the stem mount mirrors, the 2+2 bars wouldn't be tall enough to let you see out the fairing mount mirrors.
Old Sep 22, 2017 | 07:35 PM
Bodacious MC's Avatar
Bodacious MC
Thanks pswomack, the KW 2+2 might be the solution? Did you install yourself? How long did it take? Curious how many hours a shop might bill for handlebar replacement?
Old Sep 23, 2017 | 06:41 PM
pswomack's Avatar
pswomack
Yes I did the install myself, all stock wiring and cables will work, so no need to change anything, you will have to cut the factory zip ties on the clutch/brake cables where they are zip tied to the steering head and reroute them a little bit, took me maybe 1 1/2hrs, but I've been an ASE Certified Master Auto Tech for 34yrs, so it was no big deal for me, you can do it yourself and save a lot of money, hardest part is getting the wires through the bars.
Old Sep 25, 2017 | 06:17 PM
rott_lab's Avatar
rott_lab
One more question...did you need the wire extensions to run them internally in the 2+2s?
Old Sep 26, 2017 | 10:39 AM
torchmaster
I would use the extensions, for 35 bucks it makes the job much easier.
The TBW cable is long enough so just the hand control wiring needs extending.
Old Sep 26, 2017 | 04:08 PM
Bodacious MC
Thinking hard about tackling a bar change before storage. I'm a little amazed that some folks say they can do it in 1.5-2hrs. Others say the dealership charged them $800 labor?
$400 an hour sounds a bit steep for this retired blue collar worker. Once a tech does this a few times it must be easy money at that rate.
