Winter clean up
Old Dec 7, 2017 | 11:33 AM
y22c's Avatar
y22c
Spectro Motorcycle Wash. I use it on everything, including raw aluminum.
Rinse well.
Old Dec 7, 2017 | 11:50 AM
rwven's Avatar
rwven
Originally Posted by jdunn01
Thanks for the input guys.
We do have 5 gallon water delivered for drinking. I suppose I could use one of those but do not have a way to pressurize it for spraying off.
I think i will go with taking to the car wash spraying the engine down with S100 foam after it cools a bit. The main thing i need to get off is the built up road grime.
I have a compressor at home that i can use to knock the dust off.
May need to get a 12 volt yard sprayer pump (~$100) and rig it up so can use a 5 gallon drinking water bottle to spray it off after washing.
For a few bucks more you can get an ATV Spot Sprayer which would get you a tank, pump and spray wand. 1.0 GPM @60 psi should be plenty for rinsing.
Amazon Amazon
Old Dec 7, 2017 | 12:04 PM
Scudda's Avatar
Scudda
I once rented a garage that had no water hookup. I bout one of these and used a car battery to power it. It worked great!!
https://www.harborfreight.com/lawn-g...olt-61263.html
Old Dec 7, 2017 | 12:35 PM
Magnut1's Avatar
Magnut1
I bought my bike new in late 14 and only power washed the bugs off the front of it once when I rode from Toledo Ohio to Austin Texas and bucket washed it only once after I rode in the rain on the highway for 4 hours. Other than that I have only used Harley spray cleaner in a can.
Old Dec 7, 2017 | 03:52 PM
IGG's Avatar
IGG
Maybe this would work.
https://www.worx.com/hydroshot-porta...ner-wg629.html
Old Dec 7, 2017 | 07:43 PM
Rocket59's Avatar
Rocket59
6th Gear
I bought the Works washer last summer and it works really well. I was skeptical but it works as advertised. It doesn't have the power of a pressure washer but it's more powerful than a hose and nozzle. I was able to use it to clean siding on the house (attached to a hose) and under the mower deck (using just a 5 gallon bucket of water to draw from). It's very conservative on water use - it only takes a couple of gallons for a bike. The battery makes a big difference though -the standard battery doesn't last all that long and doesn't have the power of the big battery. Recharge time is a little longish though.
Old Dec 8, 2017 | 10:33 AM
dyna07custom's Avatar
dyna07custom
Simple Garden sprayer will do the rinse job. You can get a 2 gallon one at any home depot or Lowes. Wash bike normally spray clean water and dry
Anthony Cole
Mar 15, 2018 02:42 PM
Navy UC Rider
Apr 28, 2011 09:29 AM
FLTR2008TRIKE
Oct 12, 2008 08:31 AM
forever young
Apr 18, 2008 06:02 AM
