Drivers backrest
Old Jan 30, 2018 | 06:42 AM
  #31
NDRK's Avatar
NDRK
I have the Grasshopper. Cheap but it works. It pushed me forward. I took the pad off and turned it around. That gave me the little room I needed.
Old Jan 30, 2018 | 01:07 PM
  #32
Dynamite17's Avatar
Dynamite17
Default Spring?
Originally Posted by FlyingSkeet
I got the HD adjustable and it was to far forward in the back position so I had to customize it. The base is not adjustable only the back rest adjusts,it pivots in the base forward and back. I straightened the bend in the middle of the back rest and using a hydraulic press bent it right where it comes out of the base giving me the room I needed. I would not recommend it. Without the modifications it would be in the scrap pile.
Regarding the Harley backrests, I hate the way the spring just squishes between the 2 posts where it connects to the base. More than one time I've dropped the thing.
Anyone have a solution, perhaps a tack weld to attach it?
Bob
Old Jan 30, 2018 | 01:40 PM
  #33
sailmotion's Avatar
sailmotion
Bob
Are you talking about the circled area? If so, how about a stiffer spring?
Old Jan 30, 2018 | 01:45 PM
  #34
Dynamite17's Avatar
Dynamite17
Yes, that's the spring. It's a standard Harley part. Stiffer would probably tend to spring out the same, just fly further. Also make it harder to remove. Wish there were some tabs/holes etc to keep it in place.
Thanks for the reply.
Bob
Old Jan 30, 2018 | 02:26 PM
  #35
djhrln's Avatar
djhrln
I usually ride without a backrest, but on long rides I'll slip the Grasshopper on for a while.
Old Jan 30, 2018 | 02:30 PM
  #36
sailmotion's Avatar
sailmotion
Bob
That's right - I completely forgot! If you spread the arms more open [?] the spring drops out. I fabricated 2 angle-irons with holes where I hang the backrest when it's off the bike. Thus, it is generally under slight tension. How about a piece of wire or cord around both arms, just tight enough to prevent them from opening too much?
Old Jan 30, 2018 | 05:50 PM
  #37
RoadHog659's Avatar
RoadHog659
Maybe run the wire through the spring to prevent it from flying out?
Old Jan 30, 2018 | 06:26 PM
  #38
slapshot12's Avatar
slapshot12
I have the HD non-adjustable and never ride without it, 2 up or solo. You still have 3 height options with the non-adjustable.
Old Jan 30, 2018 | 11:39 PM
  #39
jbfb's Avatar
jbfb
Another Mustang user. On my last bike and my current bike. Good price great quality. But which ever way you go, there's nothing like having a backrest!
Old Jan 31, 2018 | 06:29 AM
  #40
danhahn's Avatar
danhahn
How about a piece of wire or cord around both arms, just tight enough to prevent them from opening too much?[/QUOTE]
That works pretty good. I have a zip tie around mine just tight enough for some spring pressure.
